  1. Hi
    There is a bunch of video files i would like to convert, crop, trim, resize, ...
    all of them have something different to do with.
    is it possible in avidemux for batch processing of all those files.
  2. Member usta's Avatar
    Jun 2009
    Netherlands
    I don't think so.
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Virtualdub can, but it depends on the output type you want as to whether or not it is appropriate.
    AVI Demux does have the ability to load and save projects, and a job list function. I haven't played with either of these, but that is where you need to start your search. I suspect it works like virtualdub, in that you have to set up each job manually, add it to the list, and repeat until you have all your jobs ready to go, then execute the batch and walk away.
    Read my blog here.
