I captured a video from my camcorder with my Radeon's Video In 7 program, the only format it lets you save the video in is MP2. I made a 2 minute video, and it's 18MB! What's up with that? Is there any other program I could video capture to that would allow me to save it as a DIVX or AVI file that's more compressed? TIA.
1-try VirtualDub and use the DivX codec
2-set the datarate in MPEG2 to a LOWER value...you can do this with the ATi capture software under MPG2 custom config
3-an AVI file will not compress as much as MPEG2MOBO: ASUS P4P800 Deluxe
CPU: 3 GHz P4
OS: Win 2k SP2
Audio: ECHO Mona
BSCVideo Card: ATi Radeon 9800 Pro
Video Capture: IEEE-1394 DV
HSF: Volcano 5
HDD: WD 1200JB
Video HD: WD1000BB
CD-RW: Sony
DVD-R: Pioneer A03 -
I went into the video capture program and set it to use medium quality MP2 which is 4 Mbps. Will that reduce the size of any future files I record? Thx again.
yes, but, 4MBPS is still pretty high. Video quality still looks good down to 2.5-3 MBPS. Below that , it gets pretty blocky.
CPU: 3 GHz P4
OS: Win 2k SP2
Audio: ECHO Mona
HSF: Volcano 5
HDD: WD 1200JB
Video HD: WD1000BB
CD-RW: Sony
I believe that was the lowest setting I saw. There was a setting for MP1, but that's so old it probably don't look good. I can check again later.
HIS 9600pro ATI 128Mb AGP - driver installation ???
By blinky88 in forum ComputerReplies: 6Last Post: 22nd Sep 2009, 04:52 -
ATI PCI Theatre 550/650 vs AGP AIW 7500, 9600XT
By TaranScorp in forum Capturing and VCRReplies: 3Last Post: 6th Sep 2009, 14:45 -
why does my ATI VIVO quality suck so bad
By bacobits in forum Capturing and VCRReplies: 3Last Post: 2nd Jan 2008, 20:22 -
Capturing VHS by using VIVO
By Filsps in forum Capturing and VCRReplies: 0Last Post: 15th Sep 2007, 14:17 -
resolved: Need source for software for capture through ATI VIVO card
By palouse in forum Capturing and VCRReplies: 5Last Post: 7th Jun 2007, 10:56
