Hi guys,
I am converting from .wmv to .flv
If I use the -ss flag to cut off the beginning then the audio is out of sync (I also get the red message: Buffering several frames is not supported...)
I found that if I convert the .wmv to .avi first (using FFMpeg as well) I don't get the audio sync problem when I convert the .avi to .flv
Is there a way I can do it right without the conversion to .avi ? I don't terribly mind the initial conversion so if I have to do it that way maybe I should use some special settings or convert to something other than .avi ?
Thanks.
Converting one highly compressed format to another highly compressed format isn't recommended. Doing it right involves taking a large resolution dv/avi or other lightly compressed format and converting it to flv. For what it's worth, I did have success with SUPER in converting a flv to wmv
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
Audio out of sync problem with FFMPEG encoding MP4 (h.264,AAC)
By jenak1980 in forum Video ConversionReplies: 7Last Post: 5th May 2010, 01:03 -
Mencoder // ffmpeg flv file Audio-video sync problem
By krishnareddy in forum ffmpegX general discussionReplies: 5Last Post: 26th Apr 2009, 09:13 -
FFMPEG causes certain MP4's to be out of sync
By jjones3535a in forum Video ConversionReplies: 6Last Post: 15th Feb 2009, 10:21 -
ffmpeg -- encoding while muxing new audio w/out source's audio, how ?
By vhelp in forum AudioReplies: 8Last Post: 21st Nov 2007, 19:53
