FLV Files to DVD
Did any1 here try this? Converting FLV to DVD playable standalone.
This may convert mp4 to DVD, as well.
i wud like to have some feedback on quality of DVD Video before purchase.
at present i am working for educational video MP4/FLV --> AVI --> DVD using AVIDemux with some video sharpening filters.
@ Baldrick
Thanks!
Quality - Not Too Bad while Converting FLV / MP4 Files to DVD Playable Standalone.
DVD Flick served the purpose of making an educational video DVD.
Herewith, I am submitting a DUMMY sample with different video.
Here is the sample
ORIGINAL VIDEO (HD High Quality - Higher Video Bitrate) Source
Complete name : CALIFORNIA GURLS OFFICIAL MUSIC VIDEO - Katy Perry feat. Snoop Dogg.mp4
Format : MPEG-4
Video
Format : AVC
Format profile : High@L3.1
Bit rate mode : Variable
Bit rate : 1 998 Kbps
Maximum bit rate : 6 249 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Audio
Format : AAC
Format version : Version 4
Bit rate : 125 Kbps
Maximum bit rate : 199 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
AVIDemux CONVERTED VIDEO (AVI FOR DVD)
FILTERS USED
1) ReSize : 720x400 (16:9)
2) aSharpen FILTER with HQ Mode [v] Checked
I HAVE USED AVIDemux AS A CONVERTER COZ I LUV AVIDemux, MAN!
YOU MAY USE YOUR FAVORITE VIDEO CONVERTER.
General
Complete name : Californian Gurls - SAMPLE.avi
Format : AVI
Overall bit rate : 2 436 Kbps
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Codec ID : XVID
Bit rate : 2 080 Kbps
Bit Reate is set slightly higher than 1 998 (approx 100+ than source) in order not to drop quality.
Width : 720 pixels
Height : 400 pixels
(720x400 Nearest Neghbour of 16 for DVD, actual might be 720x405)
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Audio
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : 2000
Duration : 19s 40ms
Bit rate mode : Constant
Bit rate : 224 Kbps
Sampling rate : 48.0 KHz
SAMPLE VIDEO DOWNLOAD LINKS:
1) http://rapidshare.com/files/413494066/Californian_Gurls_-_SAMPLE.avi
MD5: 786EE84DEE347DC436B55F3943D82400
2) http://www.zshare.net/video/794410427cef90e8/
Californian Gurls - SAMPLE.avi -
5.54MB
3) http://www.mediafire.com/?pl2pjofj7iz0e8e
CONVERTING into DVD
One can use DVD Flick, ConvertX2DVD, or any other DVD authoring tool.
BUNCH OF THANKS & ROSES TO HD UP-LOADERS WHO MAKE SOMEONE ELSE WEALTHY (FILTHY RICH) RATHER THAN THEMSELVES!Last edited by Bonie81; 17th Aug 2010 at 14:54.
Converting VHS tapes to FLV files using Avanti
By ABBrittain in forum Newbie / General discussionsReplies: 4Last Post: 27th Jun 2011, 04:42 -
Converting vob files to one playable file
By Boen in forum DVD RippingReplies: 2Last Post: 31st Aug 2010, 23:27 -
Converting files to FLV
By sadr in forum ffmpegX general discussionReplies: 13Last Post: 14th Jun 2008, 05:44 -
HDDVD to Blu-ray playable on standalone BR player
By miko611 in forum Blu-ray RippingReplies: 1Last Post: 30th Apr 2008, 08:26 -
Converting .flv files
By gino_76ph in forum Video ConversionReplies: 8Last Post: 28th Mar 2008, 22:06
