Hey guys,
I'm not sure where to post this, so correct me if I'm wrong.
My problem is that I'm trying to put a 1920x1080 23.976fps h264 video in that m2ts format (Using tsMuxeR) so I can edit it in Sony Vegas. It works fine, there seems to be no problems, I can edit it fine in Sony Vegas, and there seems to be no playback problem.
My only worry is that I tried to keep close to the original source by picking 24fps as framerate and when it comes to the output it doubles to 48fps. Is this a problem, why does it do this? I tried the other ones and they all double except for 30000/1001 gives me 59.940fps and 24000/1001 gives me around 487000fps (woah! haha).
Is there a fix? Or is the 48fps not a problem as long as I render back to the original source (23.976) when I'm done editing in Sony Vegas? I want to keep the best quality I can.
Maybe something wrong with your source ?
Is it native progressive e.g. from blu-ray , or telecined 24p from a camcorder ? -
My source was in an mkv. Which I used MKVtoolnix to extract only the video from, which is h264 format. I watched it entirely before putting it to m2ts so it's not corrupted. It's a download.
Here's some more detailed info on it
- 1080p, Bluray, x264, DTS
- 1920x1080, 23.976fps, 7500kbps
Not sure if that helps any, that all the info I know.
Deinterlace and doubling fps with HDconverttox?
By jiopi in forum Video ConversionReplies: 38Last Post: 30th Mar 2012, 10:15 -
MVtools/MVtools 2 frame doubling problem
By Gnodab03 in forum Software PlayingReplies: 2Last Post: 3rd May 2011, 04:14 -
Tsmuxer AVCHD problem?
By mufasa2 in forum Video ConversionReplies: 4Last Post: 22nd Aug 2010, 04:19 -
Problem with tsMuxeR...
By hiimbored in forum Authoring (Blu-ray)Replies: 8Last Post: 6th Oct 2009, 03:43 -
tsmuxer problem with sound
By privateapples in forum Authoring (Blu-ray)Replies: 1Last Post: 8th Oct 2008, 02:53
