Results 1 to 13 of 13
    May 2010
    Austin, TX
    I frequently see the noise at the bottom of the video, shown in the attached picture when capturing Hi8 video. Please ignore the main portion of the image where I've intentionally pixelated it to obstruct the main image. The noise comes and goes, increases and decreases in height at the bottom of the image.
    My heads are clean. No question. This is not my tape, and my own personal tapes do not show this, yet I've seen this on dozens of other tapes.
    The deck playing this is a Sony GV-D200. I am using the FireWire output directly into my PC. I do not know the camera model used to record this.
    What is causing this noise? Is my deck bad? Incompatibilities between Hi-8 formats?
    CYM
    Oct 2005
    666th portal
    dirty/damaged video head is what it looks like to me.
    Do not use a D8 player for Hi8 and Video8/8mm tapes. It's just not as good as a Hi8 deck or cam.
    This is common.
    May 2010
    Austin, TX
    I agree, it looks like the heads are dirty, but they are definitely not dirty. Damaged, OK. But, why do ALL of my own personal tapes look fine? Being at the end of a frame means it is after hundreds of helical scans across the tape for the good lines. What is at the end of a Hi8 frame that is different? Is it just loosing its tracking?
    This is common.
    I hadn't heard that. I don't have another analog deck to try. But, can you provide some more explanation on why multi-format decks are more prone to this? BTW, don't look at the pixelization. I did that manually to hide the image. I'm just talking about the noise at the bottom.
    CYM
    D8 decks are made for DV on 8mm tape.
    Hi8 decks are made for Hi8 tapes.
    Being made for something, and "also" doing something, is never the same.
    Jan 2007
    Republic of Texas
    That stuff at the bottom of the frame? Looks to me like the result of tape edge damage. Physically inspect the tape itself to confirm.
    May 2010
    Austin, TX
    This is a tape alignment problem. I've acquired the service manual for this deck. There are a couple of rollers that can be adjusted (with the deck cover removed) to correct this issue. The service manual refers to test alignment tapes used in conjunction with a scope trace, to flatten out some signals viewed on the scope. I don't have those test tapes, but by experimenting with the range of the alignment adjustment, I was able to find the middle well enough to eliminate the noise. Now I need to work through enough tapes to be sure I haven't just found the sweet spot for one tape.
    I like the video quality of the GV-D200, but I have found it to be a bit unpredictable.
    CYM
    Alignment/tracking data is stored on the tape itself, interleaved in the recording, for 8mm/Hi8.
    You really can't fix alignment/tracking on a 8mm tape.
    You're better off using a good Hi8 camera or deck.
  9. Originally Posted by lordsmurf View Post
    Hey Smurf,
    Usually I agree with most of everything you say expect in this case. My first video camera was an 8mm. over time the head and rollers slowly were becoming unaligned and in the end I had to get the camera repaired. However what had happened was that it gave a similar distorted look to the tapes (not all of them, just the ones when the unit started to go wonky) at the bottom of the screen. I did get the unit fixed, but at that point i then picked up a Hi-8 camera
    When converting the "damaged 8mm tapes" (to disc) some of them would not even play correctly in the hi8 (pic would roll) or others had more "noise" at the bottom of the pic, similar to what the original poster supplied. In the end I had to rig up the old 8mm camera to work and constantly adjust the rollers per tape as I was doing conversion. You were also able to see just how unaligned the machine was getting as I transferred more tapes and had to keep adjusting the rollers
    So though you had mentioned that Alignment/tracking data is stored on the tape itself and that it cannot really be fixed, I saw the opposite occur. I was able to get my tapes working and had the noise disappear and just getting a better machine might not really fix the problem
    However in cym's case I would try to get some sort of actual hi8 machine itself and see if that does fix things rather than using a D8 machine for the conversion
  10. Video Restorer lordsmurf's Avatar
    Well, you're basically "breaking" a camera to match the tape.
    You may never get it back to the proper alignment again without service manual specs and tools.
    That's best done with a scope.
    Some of this is explained a bit more at http://www.digitalFAQ.com/forum/showthread.php/8mm-playback-problems-1602.html
    VHS was easier to align with some simple testing.
    I f'd up another one recently, however, screwed up the transport on it beyond repair.
    Then it proceeded to butcher one of my test tapes. Sounded like fingernails on chalkboard.
    Oh well, it gave me 14 good years.
    May 2010
    Austin, TX
    The adjustment to the tracking made a significant difference. I went from seeing this on 95% of the tapes to pretty much not at all. I'm not tuning per tape. This just adjusts the angle the tape tracks across the helical scan head. This is a very coarse adjustment, and I'm guessing the tracking information encoded on the tape is for finer auto-tracking. BTW, if you have a link to a spec that describes the physical encoding of Hi8/Video8/Digital8 on the tape media, I'd love to read it.
    I do encounter customers where many of their tapes don't play well, such as dropouts, but that could be due to their own care for the tapes, or if they've played them back a lot.
    Lordsmurf, I'm definitely considering getting an analog deck for the Hi8 tapes. What's your preferred deck? I don't really want a camera. I convert a lot of tapes for customers, and need something that can stand hours and hours of use, is serviceable, etc. I don't mind refurb decks, if you can recommend an outfit you trust.
    CYM
  12. Video Restorer lordsmurf's Avatar
  13. I'm having the same problem.
    Trying to transfer my Hi-8 tapes to PC using the original camera they were recorded with (Samsung scl810 8mm camcorder Hi-8).
    My tapes have the line (like in OPs pic) going across the top and sometimes at the beginning of the tape, the whole tape is kind of noisy.
    I really don't know what to do and I read the responses here, but don't really understand how to align the tapes and if its the right thing to do.
    Edit / Now the tapes wont play at all, even though I know for sure there are recordings on it, it just shows that static screen or whatever you call it. Earlier they have been playing without problems (minus the noise)
