Hi,
I've tried the x264.exe encoder. Works great but i have a question, why is the 2 pass mode 4 times slower than the 1 pass mode ??? Theorically a 2 pass mode would be 2 times slower not 4.
I tried it with the following settings:
source: 720*576 DVD mpeg2
with 1 pass: x264.exe --bitrate 1000 --pass 1 ==> about 26 fps encoding speed
with 2 pass: x264.exe --bitrate 1000 --pass 2 ==> about 6 fps encoding speed
which such a decrease in encoding speed ???? I though i got about 12 - 13 fps
I run it on Windows 7, 1,5 GB DDR RAM on an Athlon 64 3500+
You're not comparing single pass with two pass encoding. You're comparing the speed of the first pass vs the speed of the second pass of a 2 pass encoding. The default for the first pass is to skip some of the details to make it faster. Ie, the first pass is much faster than the second pass where the real work is done. If you performed a single pass encoding it would be close to the speed of the second pass of a 2 pass encoding.
x264, point of 1st Pass encoding?
By Sephisto in forum Video ConversionReplies: 50Last Post: 18th Apr 2012, 02:13 -
x264 encoding occurs too fast in pass 1
By codemaster in forum DVD RippingReplies: 5Last Post: 21st Sep 2011, 22:28 -
2-pass Parameters for x264 / BluRip
By nikemouse in forum Newbie / General discussionsReplies: 2Last Post: 25th Mar 2010, 18:18 -
x264 - new pass with different dimensions, is it OK?
By kurbads in forum Video ConversionReplies: 16Last Post: 5th Sep 2009, 07:57 -
Mencoder x264 2-pass in Windows
By blazerqb11 in forum Video ConversionReplies: 0Last Post: 22nd Nov 2008, 09:54
