my sony dvd player (dvp-ns67p) has no picture. i tried to play a divx dvd and then it didn't show the picture anymore. i tried some different cables and checked all connectors. but it still doesn't work. is it a software problem? or hardware? what should i do?
Check the users guide that should have come with the unit, the problem may be resolved by simply resetting the unit. Meanwhile try hooking it up to another tv. Assuming the audio still works you might try running an opitcal lazer cleaner, if that fails it's likely kicking the bucket.
thank you for your reply. i will try resetting it if possible. i have tried with another tv but no result.
Want to change zone DVD player Sony DVP-NS67P
By Torvisse in forum Newbie / General discussionsReplies: 10Last Post: 17th Jan 2011, 12:33 -
SONY DVP-SR700H - squashed DivX picture
By jhrebacka in forum DVD & Blu-ray PlayersReplies: 2Last Post: 9th Nov 2010, 11:21 -
My Sony DVD player SONY DVP- NS718 H
By samyer in forum Newbie / General discussionsReplies: 1Last Post: 3rd Feb 2010, 00:56 -
problem with playing divx files on sony NS67P ?
By cccf25 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 8th Feb 2008, 08:57 -
Which do you prefer: Panasonic dvd-s2 or Sony ns67p?
By cccf25 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 6th Feb 2008, 15:31
