A friend of mine gave me a SVCD-movie on 2 cds but since it's only 80 min long i want to convert it to VCD.
Here is my problem.
I can play mpeg-2 on my PC, but this movies can't be played from the CD. I have to Get the file by using "ISOBUSTER" which is Okay since I want to join the 2 files. But... but the files are weird WMP won't open them, only AsusDVD 200, DVD2AVI makes a useless project, VFAPI won't open it. I found out that the streaming is mpeg-2 program (VBR) and not SVCD (VBR), if I try to make the stream into something usefull (SVCD) TMPGenc stops at 140mb out of 787mb. FlaskMpeg wont even try to open it.
What can I do about it? It must be posible to be convert/edit/do-something about thise files.
My system:
AMD Duron 700Mhz@770Mhz
256 mb PC133
Geforce2 MX 32mb
M$ Windows2000 SP2
Help needed converting HD h.264 Freeview recordings (New Zealand)
By Chopmeister in forum Video ConversionReplies: 26Last Post: 25th Sep 2011, 02:18 -
Help needed Converting to AVCHD to play on Panasonic TV
By LOWTECH in forum Video ConversionReplies: 8Last Post: 31st Aug 2011, 12:52 -
help needed converting and editing an flv please
By Witzend in forum Newbie / General discussionsReplies: 6Last Post: 23rd Aug 2011, 15:04 -
trouble converting/xb360 essential settings needed
By Captain Slow in forum Newbie / General discussionsReplies: 8Last Post: 17th May 2011, 19:14 -
Help converting YUV420 to RGB565 needed
By cheetahace in forum ProgrammingReplies: 3Last Post: 18th Apr 2008, 02:15
