have audio from a pal source in ac3 format that i removed from mkv via mkvextractgui (tsumuxer for some reason wouldnt recognize it).
but nothing ive tried to go from 25 to 23.976 has worked
eac3to - detects clipping, then the created file is all garbled like a slowed down tape
besweet (through gui) - creates a file that at least is intelligible, but there is popping and clipping at many parts
behappy - creates a file, but when i play that file it is completely silent
here is the info for the audio in the mkv
Audio
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 2h 14mn
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 369 MiB (5%)
Language : English
however, after extraction, it says that there are 6 channels in the ac3 i am trying to convert
Format : AC-3
File size : 369 MiB
Duration : 2h 14mn
Overall bit rate : 384 Kbps
Audio
Format : AC-3
Duration : 2h 14mn
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Bit depth : 16 bits
Stream size : 369 MiB (100%)
HELP!!!
Results 1 to 1 of 1
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
pal audio convert in ntsc audio?
By ashe09 in forum AudioReplies: 4Last Post: 12th Oct 2011, 05:49 -
convert audio from PAL to NTSC
By Ankin in forum Newbie / General discussionsReplies: 18Last Post: 15th Aug 2009, 17:13 -
how do i convert PAL audio to NTSC?
By just in forum Newbie / General discussionsReplies: 4Last Post: 24th Oct 2008, 13:20
