I have a movie in mkv file and the size is larger than 4GB which cannot be moved to HDD (FAT). I read from the forum that I can cut the original file into smaller ones, then move to to HDD and merge them. The suggestion from the forum was to use Mkvtoolnix to cut and merge the files. I installed Mkvtoolnix 2.3 for older version of mac os x10. I was able to cut the file and move them to HDD, but was unable to merge them. I am really new to this cutting/merging and was hoping that anyone can help me with the detailed instruction/step by step on what to do? Do I need to check any box in particular or set any parameter before I cut the file? How can I merge these files?
Any helps/instructions would be appreciated. Thanks!
FAT32 has a maximum allowable filesize of 4GB, so even if you do cut the file up and copy it over, you cannot merge the pieces back together again. If you want a single file you will have to re-e,cde the file (either video or audio or both) at a lowr bitrate so that it fits under the 4GB limit.
Read my blog here.
MKVToolnix merging help
By SunnyHours in forum MacReplies: 7Last Post: 2nd Dec 2010, 15:39 -
mkv wont play after merging .srt file to it
By vice86 in forum SubtitleReplies: 2Last Post: 27th Oct 2010, 22:41 -
MKV file help using MKVtoolnix
By KoolK in forum Newbie / General discussionsReplies: 1Last Post: 11th Oct 2010, 20:16 -
Remuxed mkv using mkvtoolnix leaves file unplayable
By micnolmad in forum Video ConversionReplies: 4Last Post: 10th Jul 2010, 11:33 -
Cutting an mkv file
By CheekyKid in forum EditingReplies: 0Last Post: 14th May 2009, 11:48
