I have a DIVX avi here with AC3 multiplexed in it.
When I try to convert it to VCD using TMPeg I have no sound.
I thought no problem.
I tried to use virtualdub to demultiplex the AC3 track.
2 problems. - If I use direct stream copy and then save wav it only extracts half of the AC3. - when I try it with full processing mode it give following error. " The requested audio compression is not compatible with the input format."
I hope somebody can help me out here and tell me what is the best way of converting a DIVX with AC3 to MPG stereo
CU
it worked with the standard version of virtualdub for me...to demultiplex only then...not convert to wav. you could try with nandub www.nandub.org
TNX
Nandub seems to be be the program for me.
Thank you all for the replies.
:D -
I'm having the same problem as well. But I can't figure out how to demultiplex it with nandub, can anyone give me a quick run by on how to do it? =p
Avi to Ac3 user guide. How to encode the audio from an avi to ac3 .
By freebird73717 in forum User guidesReplies: 5Last Post: 9th Dec 2009, 22:53 -
Convert AVI with H264 and AC3 to AVI with XVid and AC3
By ashwin.terminator in forum Video ConversionReplies: 4Last Post: 26th Jul 2009, 12:17 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 11:24 -
converting mpeg2/ac3 and avi/ac3 to avi/lambmp3
By corumz in forum Video ConversionReplies: 2Last Post: 17th Sep 2007, 10:32
