  1. humpybong
    Aug 2010
    Brisbane, Australia
    I have downloaded an old VHS video tape to my computer and it is in .mpg format.
    What formats can I use on my DVD player to view this on my TV.
    I have converted to DVD but the result (AUDIO_TS and VIDEO_TS) display a rather great loss of picture quality.
    This is my first try at doing this so I still have my "L" plates on.
    Any advice would be appreciated.
    Barry
    Aug 2002
    South Florida
    Garbage in garbage out. How good was the VHS tape to begin with? If the tape does not have Macrovision on it, it could be a poor quality tape. I send my tapes through my JVC DR-M10S recorder and it improves the quality of the output. I also have a stabilizer to remove Macrovision when called for.
  3. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Well, we don't know, what formats will YOUR dvd player play ?
    How exactly or with what, did you Transfer, CAPTURE, "download" your VHS tapes to your PC ??
    How did you convert them ?
    From what with what ?
    How much did you put on 1 dvdr ?
  4. humpybong
    Aug 2010
    Brisbane, Australia
    The VHS tape was made in 1990 using a National VHS camera.
    I transfered it to my Dell laptop using Ulead VideoStudio SE DVD and all looks great on screen.
    Then converted to DVD format using a freeware program called Freemake Video Converter.
    When I played the DVD on my Panasonic Digital Recorder/Player the loss of picture quality was very evident.
    This VHS tape holds some old family memories.
  5. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Freemake Video Converter ? Never heard of it, but it sounds like the type of crap that people often spam us with.
    If you already have the DVD edition of video studio, why not use it to encode and author the disc ?
    Otherwise have a look at the free AVStoDVD, which uses a high quality encoder (HCEnc) and does a pretty good job.
    Read my blog here.
  6. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Most likely it's because your initial capture size or resolution was too small(nowhere near 720x576). All video looks "great" when it is the size of a postage stamp(compared to full size).
