I am getting ready to convert all of my music CDs into FLAC files on my hard drive. I have found out that in order to rip them accurately, I need to use a special program like EAC or dbPowerAmp.
Now if audio CDs require special programs to be ripped accurately, I wonder why movie DVDs and data CDRs/DVDRs don't require anything special? If you want to copy an unencrypted movie DVD, or a data CDR/DVDR, you can just use Windows Explorer to do it, and it will do it accurately. Why does a music CD require special software? They are all digital media, so I don't understand why a music CD would be different from a movie DVD or a data CDR/DVDR.
Audio CDs are recorded as raw binary data on the disc with little facility for error detection/correction. DVDs are recorded with a full file system with data redundancy for error detection and correction (much like a hard drive). So when ripping from a DVD most errors are fixed before the program even gets the data. And when the errors can't be fixed the program knows about it. All the DVD rippers I've seen allow you to specify multiple retries when errors are encountered.
FYI:
DVD+R has better error correction than DVD-R: http://www.myce.com/article/Why-DVDRW-is-superior-to-DVD-RW-203/Conclusion-1/
Audio CD's use mode 2 which bypasses most error detection and correction so you can put more data than mode 1(780MB vs 700MB): http://www.cdrlabs.com/forums/mode-versus-mode-discs-t8075.html
When ripping audio CD's you should select error correction in the software, it may take longer to rip but it's worth it. Some brands work better than others, Lite-On's and Plextors are excellent rippers because they report C1/C2 errors:
http://stason.org/TULARC/pc/cd-recordable/2-17-Why-don-t-audio-CDs-use-error-correction.htmlLast edited by MOVIEGEEK; 14th Aug 2010 at 21:59.
Thanks for the helpful information, guys!
I have a 9-year old TDK 12x10x32x CD writer - it is actually a rebadged Plextor. Do you think such an old drive will still be good for ripping CDs? I actually do have a newer NEC Optiarc DVD writer that I suppose I could use to rip my CDs, but I don't want to subject that to the wear and tear of ripping hundreds of CDs.Some brands work better than others, Lite-On's and Plextors are excellent rippers because they report C1/C2 errors -
If you don't get pops, fizzles and clicks in your ripped CD audio, then it was ripped perfectly fine.
Like hech said, some dweeb lied to you.
The music won't change pitch, or some other nonsensical BS of that nature.Want my help? Ask here! (not via PM!)
Are there some DVDS that will "self-erase" if you try to cloan/copy them?
By slazar in forum DVD RippingReplies: 9Last Post: 30th Jul 2011, 16:23 -
Getting "Fair Use" copy of last "Byrds of Paradise" episode
By Ronald Vaughan in forum Newbie / General discussionsReplies: 4Last Post: 14th Jul 2010, 21:09 -
How to get an "l"not an "I" when ripping the dvd subtitle to text format
By cairuitao123 in forum SubtitleReplies: 12Last Post: 24th Mar 2010, 20:50 -
Blu-Ray "special editions" coming?
By ryangarfield in forum Off topicReplies: 6Last Post: 15th Mar 2008, 07:03 -
Aspire Digital AD-8091 DVD Recorder "skips" when records programs
By ray2000 in forum DVD & Blu-ray RecordersReplies: 16Last Post: 14th Feb 2008, 08:57
