Results 1 to 11 of 11
    Dec 2004
    England
    I'm trying to re-encode an upscaled (4:3 pillarboxed) 720p50 h264 transport stream to 576i so I can burn it to DVD. I used DGAVCDec to extract the audio and create a *.dga file, which I then put through an AVI Synth script to resize etc. I then loaded the *.avs file into HCEnc, but when I hit Encode I get the following error:
    It appears after a few seconds of encoding and the program closes.
    I don't understand the error at all, so what can I do?
    I don't know if it helps, but below is the MediaInfo log of the source file:
    General
    Format                           : MPEG-TS
    File size                        : 11.2 GiB
    Duration                         : 2h 0mn
    Overall bit rate                 : 13.3 Mbps
    Video
    Menu ID                          : 11110 (0x2B66)
    Format                           : AVC
    Format/Info                      : Advanced Video Codec
    Format profile                   : Main@L4.0
    Format settings, CABAC           : Yes
    Format settings, ReFrames        : 5 frames
    Format settings, GOP             : N=16
    Duration                         : 2h 0mn
    Bit rate mode                    : Variable
    Bit rate                         : 11.8 Mbps
    Maximum bit rate                 : 12.0 Mbps
    Width                            : 1 280 pixels
    Height                           : 720 pixels
    Display aspect ratio             : 16:9
    Frame rate                       : 50.000 fps
    Color space                      : YUV
    Chroma subsampling               : 4:2:0
    Bit depth                        : 8 bits
    Scan type                        : Progressive
    Bits/(Pixel*Frame)               : 0.255
    Stream size                      : 9.90 GiB (88%)
    Color primaries                  : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
    Transfer characteristics         : BT.709-5, BT.1361
    Matrix coefficients              : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
    Audio #1
    Format                           : MPEG Audio
    Format version                   : Version 1
    Format profile                   : Layer 2
    Duration                         : 2h 0mn
    Bit rate mode                    : Constant
    Bit rate                         : 256 Kbps
    Channel(s)                       : 2 channels
    Sampling rate                    : 48.0 KHz
    Video delay                      : 140ms
    Stream size                      : 221 MiB (2%)
    Language                         : German
    Language, more info              : Clean effects
    Audio #2
    Format                           : MPEG Audio
    Duration                         : 2h 0mn
    Bit rate                         : 192 Kbps
    Video delay                      : 33ms
    Stream size                      : 165 MiB (1%)
    Language                         : German
    Audio #3
    Format                           : AC-3
    Format/Info                      : Audio Coding 3
    Mode extension                   : CM (complete main)
    Duration                         : 2h 0mn
    Bit rate                         : 448 Kbps
    Channel positions                : Front: L R
    Bit depth                        : 16 bits
    Video delay                      : -13ms
    Stream size                      : 386 MiB (3%)
    Language                         : German
  2. What version of HCEnc ? Try the new HCEnc beta released a few days ago . It fixed some issues with DGNVtools . And older builds of HCenc had known issues with DGAVCDec (I mean really old builds)
    Is your script ok ? Can you preview it in vdub, or avsp ?
    Dec 2004
    England
    I upgraded to the latest version of HCEnc and I still get the same problem.
    The script opens OK in VDub and AvsP, but if I then press the right arrow key and scroll through the frames (in VDub) it crashes after seven seconds into the video (the same as with HCEnc). But, if I open it and drag the scroller to somewhere in the middle of the video it works fine. If, after doing that, I then drag the scroller back to the beginning of the video and scroll through the frames with the right arrow key as before it works fine, not crashing! I get exactly the same with AvsP as well.
    Maybe there's an error in the original transport stream?
  4. Member Alex_ander's Avatar
    Oct 2006
    Russian Federation
    Try to apply DGAVCIndex to demuxed h264 (use TSMuxer etc.).
    Do you interlace it in script (you only mentioned resizing) or expect it from HCEncoder?
  5. Yeah, that's what I noticed as well. You didn't try and encode progressive 50fps for DVD, did you?
    That may not explain the crashes, though.
  6. Originally Posted by genak View Post
    Yes. Or a bug in the decoder. Actually, it's a bug in the decoder if it crashes -- ever, even if there is an error in the compressed video being fed to it.
    Dec 2004
    England
    I did this and I get the same error.
    Yes, the AVI Synth script outputs 576i25.
    Is there not much I can do then? It doesn't really matter too much; I can just keep the transport stream...
  8. I would try using a DirectShow decoder (DirectShowSource()) instead of DgIndex. I suspect your source uses PAFF or MBAFF which DgIndex can't handle. ffdshow, CoreAVC, Divx all handle those features properly.
    Dec 2004
    England
    I installed ffdshow and changed the script so it loaded using DirectShowSource(), but when I try to preview it with VDub, I get the following error:
    Avisynth open failure:
    DirectShowSource: Could not open as video or audio.
    Video returned: "DirectShowSource: couldn't open file ... the source for this file could not be loaded."
    Audio returned: "DirectShowSource: couldn't open file ... the source for this file could not be loaded."
    I guess there's something wrong with my script?
    DirectShowSource(\"--.ts\")
    Crop(160,0,-160,-0)
    Lanczos4Resize(720,576)
    SeparateFields.SelectEvery(4,1,2)
    Weave()
    ConvertToYV12()
  10. Do you have a DirectShow TS reader/splitter installed? Try Haali.
    Dec 2004
    England
    Thanks, I installed Haali and it seems to be encoding fine now
