Hey guys,
Some of you guys may remember that I posted this a while ago: https://forum.videohelp.com/threads/314103-FPS-issue?p=1951749#post1951749
I am still having roughly the same issue, but I'll simply explain so you don't have to look at that link. I also have a feeling I am trying to do something that my camera is not able to cope with or I am trying to achieve something that isn't possible.
So, I am recording in 1920 x 1080 50i. I take the footage to my PC, copy it off and am able to play it in Windows Media Player 11 (or 12, not sure what version, I am on Windows 7). The details of the recorded files say it was recorded at 25fps and the footage is really smooth and crisp.
I then take it into Adobe Premiere Pro CS4 and do whatever it is I want to do with my footage (simple editing). I go to export with 1280 x 720 25fps settings and it just turns the footage into a mess of blur. The crisp smooth movement of whatever I record is gone and is replaced with horrible ghosting.
My question is, what encoder am I best to use to try and retain the smooth movement of my raw files? I have tried so many settings and so many encodes that I am losing my mind? Is the smooth crisp movement only obtainable if I keep the footage in its original format?
Cheers!
you are probably rendering out progressive 25fps , so you are single rate deinterlacing
the original is 25fps or 50 fields per second . It's interlaced. Each second is represented by 50 motion samples instead of 25 , so motion appears smoother.
in order to render out the same motion samples, but progressive, you would have to double rate deinterlace (or bob deinterlace) to 50p -
Hey Poison, many thanks for your response!
Are you able to shed any light into how I might 'double rate deinterlace' to 50p?
I'm using CS4 Premiere Pro. Can this be done within Premiere Pro or will I have to do this in a 3rd party program before bringing it in to Premiere Pro? -
Some avisynth deinterlacing filters are just as bad as Adobe's deinterlacing. Be careful.
Good ones (but very slow to process) would be tempgaussmc (and it's derivatives) , or yadifmod+nnedi2/3
Normally you would set it to bob deinterlace (so 1080i50 becomes 1080p50) , then resize after. You cannot do a straight resize on interlaced material (fields get all mashed up)
Cut AVCHD not aligned at the frame boundary
By cheerful in forum Newbie / General discussionsReplies: 1Last Post: 3rd Aug 2010, 22:54 -
Looking for software to use as an AVCHD frame cutter
By sebaz in forum EditingReplies: 2Last Post: 19th Sep 2009, 15:29 -
Pinnacle Studio 12 frame rate error for Panasonic AVCHD Lite mts files
By dewispew in forum EditingReplies: 10Last Post: 13th Jul 2009, 03:13 -
Bit Rate And Frame Rate
By bharathi_n_r in forum Video ConversionReplies: 2Last Post: 30th Nov 2007, 06:48 -
Frame rate conversion by changing frame count
By asmaa in forum Video ConversionReplies: 2Last Post: 1st Aug 2007, 11:15
