I have been downloading football games and often--but not always--notice video blurring whenever there is a lot of action. The bitrate of the MP4 files is a respectable 1500 Kbps and the format is PAL at 25 fps. Do I need to de-interlace the video to get smooth motion? If so, what mode (interpolate? blend field?) and what field order should I use (keep top field? Double framerate)?
Results 1 to 11 of 11
Djard
medfaith@yahoo.com -
Don't waste your time. The motion detail was thrown away when the video was encoded to mp4. You cannot get back what was lost.
Simply put: Action + 25fps (or 24 or 30) = BLUR. It is to be expected. You want sharpness with action, shoot+capture at 50/60fps (or higher if you can).
And then, like filmboss80 said, don't compress to a codec that uses lossiness+motion-estimation as it's main way of keeping the filesize down. Once again, it is to be expected in those situations.
Scott -
"I have been downloading" .......... this phrase never ends well.
That clears it up. Because MP4 technology is newer, I thought such video files were superior. Evidently not necessarily so. Thanks for the help.
I'm not sure what LordSmurf is intimating.Djard
He think means downloaded video files can be a source of endless problems due to incorrect encoding and such.
Yep, he's correct. I wonder why so many smart rippers edit ideo without regard for the I (key) frame. Maybe someone can post a simple tutorial on how to encode/recode video files without ignoring the essentials. It's not that difficult with so many free tools available.
Djard
Read my blog here.
Sometimes newer is just newer, period -- not better in any measurable (or realistic) way.
The narcissism of many people, for example, thinking we're smarter than our ancestors.
We're really not any smarter than people 500 years ago. We just have more information.Want my help? Ask here! (not via PM!)
blur two locations of a video Mpeg2-TS
By prisoner in forum EditingReplies: 5Last Post: 26th May 2011, 01:14 -
Remove "motion blur" or at least reduce it.
By cd090580 in forum RestorationReplies: 9Last Post: 18th May 2009, 20:03 -
Blur small section of video
By zakman in forum EditingReplies: 4Last Post: 9th Mar 2009, 18:55 -
youtube video is very blur!
By yunakokimama in forum Video ConversionReplies: 1Last Post: 14th Oct 2008, 15:16 -
Blur edge of video in vegas?
By macca1980 in forum Newbie / General discussionsReplies: 5Last Post: 29th Apr 2008, 02:37
