Since I switched from XP to Windows 7 I had to install Sony Vegas Pro. 9.0 again. I also used the opportunity to updated the version to 9.0e. But I now have the problem that when I open an existing .veg file and the path for an asset link can't be found, it no longer gives me the option to search for that asset, like it did with the previous installation. I now have to manually specify the new location of the asset. Is this behavior normal? I wonder if this has something to do with either Windows 7 or the 9.0e update?
I'm going to say that it's probably the updated version not allowing you to open your previous files. When I installed Vegas 9.0 on my computer that runs on Windows 7 it wasn't allowing me to edit .avi files. I had to download and install a .avi to .mpeg converter before I could edit anything. Now everything is working out perfectly. http://www.youtube.com/user/TheCherryChurch#p/a
Sony Vegas Pro 10
By av.sorong in forum EditingReplies: 16Last Post: 9th Oct 2011, 13:27 -
Does anyone know if Vegas Pro 8.1 will work with windows 7?
By ingeborgdot in forum EditingReplies: 2Last Post: 11th Nov 2009, 21:30 -
Sony Vegas - Windows
By scidadle in forum EditingReplies: 3Last Post: 14th Jul 2008, 23:59 -
Sony vegas 8 pro help
By jaycool1995 in forum EditingReplies: 2Last Post: 31st May 2008, 14:58 -
Problems running Vegas 6 with Windows XP X64 Pro
By aplhunter in forum ComputerReplies: 1Last Post: 22nd Jul 2007, 10:21
