I recently bought a Blackmagic Intensity Pro in order to record Xbox 360 gameplay. I've got it all hooked up correctly and whatnought. My problem is when I try to record using the compressed Motion JPEG option, it drops frames. When I import a say, 10-minute video into Sony Vegas, the video track is around 30 seconds shorter than the audio track making everything out of sync and unusable.
Interestingly enough, I don't have this problem when recording uncompressed (the 8-bit YUV option). This surprised me since I'm recording to a single 500GB hard drive (not RAID). However, as a 6 minute video is almost 40GB in this format, this isn't too convenient. I'd much rather record compressed, since the file size is around a tenth of that, with barely any notable loss in quality.
My system is as follow:
Dell Inspiron 530
2.20 GHz Intel Core 2 Duo
2x 500GB hard drives (the one I'm recording to I use exclusively for recording and it gets around 130MB/s write speeds).
3GB RAM
Asus (ATI) Radeon 4650 graphics card.
I'm recoding using Blackmagic Media Express.
I have no idea why I can't record properly compressed, but I can fine uncompressed. Is it a hardware issue, or a software issue, perhaps with the codec or something? Any help would be great.![]()
Mine appears to be doing the same, When I run Uncompressed the video is fine, bit laggy on the final video but that's because of my rubbish harddrive
being sorted now though.
When I do Motion Jpeg the video lag's like crazy, there are dropped frames all over the place and the video FPS is shocking. I am currently using Windows 7 32bit with the latest Media Xpress -
Yeh I'm having that same problem using the MJPEG encoding usually when I'm recording for a long period of time it happens, but i want to find a solution to it with out me having to go out to buy a whole new capturing device
Blackmagic Intensity Pro Help.
By MoonVid in forum Capturing and VCRReplies: 1Last Post: 4th Nov 2011, 16:10 -
Blackmagic Intensity Pro 3.5.1
By Lynas in forum Capturing and VCRReplies: 24Last Post: 10th May 2010, 13:28 -
Blackmagic intensity pro help
By Smify123 in forum Newbie / General discussionsReplies: 3Last Post: 12th Feb 2010, 11:19 -
Dropping frames with Intensity Pro
By kILLDR3n in forum Capturing and VCRReplies: 9Last Post: 4th Jan 2010, 15:40 -
Blackmagic Intensity OnAir 2.0 stereo-mix recording?
By Martz in forum Capturing and VCRReplies: 0Last Post: 23rd Feb 2009, 03:32
