Hey guys,
I installed AutoGK for adding a subtitle track to a video file but each time I open the AutoGK program, it doesn't give the option to add a "subtitle track" and there is no "drop-down" menu at the side of the "subtitle/s track" window to allow you to add a subtitle track ?
Any help would be greatly appreciated guys
	After opening the AVI, hit CTRL-F8 and you'll get the option to add an external subtitle file:
 https://forum.videohelp.com/threads/256625-How-to-add-permanent-subtitles-with-AutoGK-a...I-DivX-or-XviD
	Thats great, thanks manono.
 Do you also have to select one of the options in the "Advanced settings" window such as checking one of the boxes for "Display only forced subtitles" or "Use external subtitles" ?
 Also, I have a few AVI's with a seperate srt file and when I preview the video file after adding it to AutoGK, it seems to add the subtitles automatically? So do you still have to use CTRL- F8 to add External subtitles if it seems to automatically add them?
 Anyway, thanks again for your help and advice manono.
 Regards......
	No, don't do either of those things when you're adding in your own subs.
 No, it's just playing your SRT subs along with the preview video. When you add them using the CTRL-F8 trick, if both video and subs are named the same (Movie.avi and Movie.srt, for example), you should see 'double subs', one the one added to the video and one added by the subtitle engine of the player.Also, I have a few AVI's with a seperate srt file and when I preview the video file after adding it to AutoGK, it seems to add the subtitles automatically?
 If you want those SRT subs burned into or hard-coded into the video, the only way to do that is with CTRL-F8.
  Mac version of VLC is less functional than the Windows and Linux versionBy HitTheRoad in forum MacReplies: 12Last Post: 30th Oct 2011, 04:48
  SUPER version 39 is broken - reinstall older version?By castalla in forum Video ConversionReplies: 7Last Post: 3rd Nov 2010, 19:20
  DivX 7 pro in AutoGK Newest version?By helionfilm in forum Video ConversionReplies: 12Last Post: 26th Feb 2010, 05:46
  where to download old version of dvd fab??? error in new versionBy willhenderson in forum Newbie / General discussionsReplies: 1Last Post: 1st Dec 2007, 17:00
  AutoGK missing subtitles when converting Asian version of DVDBy magicjohnson in forum DVD RippingReplies: 4Last Post: 22nd Oct 2007, 19:38
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
