Hi guys, I have a Panasonic HDC SD5.
This cam has two record sizes, 1920x1080 and 1440x1080. Logicaly 1440 has more wide screen.
But when I look at both videos with Windows Media Player Classic, then both look same.
So I mean there is no distortion in the width or height at all.
But I figured out that the 1440 video properties show one time 1920 and one time 1440.
But what is going on here? I am trying to figure it out but cannot. Please see below files.
Advice please.
KR
KC
Results 1 to 14 of 14
Frame size does not equal display aspect ratio. Many codecs and containers support non-square pixels or display aspect ratio flags. With those any frame size can encode any aspect ratio.
Same way 720x480 or 720x576 DVD displays 16:9.
http://www.kiva.org/about -
To keep it simple. For video purposes 1440 and 1920 are the same. One uses pixels that are square in size, so it requires 1920 of them to fill the space with video. The other uses pixels that are rectangular (wider pixels) so the video only requires 1440 of them to fill the screen. When you playback the video in most players or TVs, they recognize which format and adjust the way they display the video to fill the screen.
so in clear words, all record modes are same. it does not matter if 1920 or 1440, output is always the same.
correct? -
not quite the same. the output display is the same size, but the source files are different. 1920 uses square pixels, 1440 uses wide 4:3 shaped pixels. the recorded bitrate is probably lower also. for the best overall quality use the camera's highest 1920 setting. the file size will also be larger.
Display proportions are the same, 1920 version gives more detailed, horizontally sharper image.
Relatively the same. They will both fill up your HDTV and look identical. As mentioned above, the extra pixels will make the video a tiny bit sharper, but I can't imagine it being noticeable on any TV.
I hope this doesn't complicate matters further but when you start relating 1920x1080 vs. 1440x1080 to picture quality,
you also need to include bit rate and compression codec in the discussion.
Most AVCHD camcorders use a 24 Mbps bit rate for 1920x1080 and 16 or 17 Mbps bitrate for 1440x1080. 24/16=1.5
so the bit rate per horizontal pixel is equivalent. The result is proportional increased horizontal resolution with similar
compression artifacts.
As implied above, many camcorder optics and/or HDTV sets will show little difference between 1920 and 1440 settings.
But a camcorder with high quality optics/sensor and processing will show a difference when displayed on a high end
1920x1080 HDTV.
Home camcorder recordings often have long term application. In 5 years when you get a better HDTV, you are more
likely to see the difference. The situation is similar to shooting EP vs. SP with VHS.Recommends: Kiva.org - Loans that change lives.
Next level of discussion is whether horizontal resolution or bit rate is more important to picture quality. Increasing bit rate
will decrease compression artifacts.
So in this context many producers would rather shoot 1440x1080 at 24 Mbps or 50% more bit rate per horizontal pixel
for fewer compression artifacts.Recommends: Kiva.org - Loans that change lives.
Edit 1440 and 1920 HD together
By akkers in forum Video ConversionReplies: 2Last Post: 25th Nov 2011, 11:01 -
Resize aspect ratio.
By Benhermies in forum Newbie / General discussionsReplies: 3Last Post: 12th Feb 2011, 22:29 -
Avisynth Aspect Ratio Resize Help
By t4com4 in forum Newbie / General discussionsReplies: 9Last Post: 1st Oct 2010, 10:30 -
Aspect ratio
By ngc7088 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 11th Mar 2010, 11:25 -
Aspect Ratio
By thesuperhemanshow in forum EditingReplies: 0Last Post: 5th Jan 2009, 16:36
