  1. Hi
    I'm using staxrip for my encodes and recently i had been experimenting with codec settings in staxrip for getting better picture quality at lower bitrates. So i encoded a ripped movie file and the output was awesome, i could hardly see any difference in the quality but annoyingly, I notice artifacts in several 'fast-motion' and 'dark' scenes. Please help me to adjust the codec settings to ensure that such artifacts do not appear in my next encode.
    I've attached a file containing some screenshots of such artifacts.
    These are my encoding settings:
    cabac=1 / ref=8 / deblock=1:-2:-1 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=4 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=617 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.50
    Thanks in advance
  2. this looks like decoding errors, not encoding settings problem
    what software for playback ? what decoder ? Try something else, like MPCHC, or SMPlayer - do the artifacts still remain ?
    weightp is known to cause this sort of problem with some decoders, you can try disabling it
  3. Originally Posted by poisondeathray View Post
    I'm using MPCHC for playback. Er.. how should i disable weightp? do you mean the weighted b-frames prediction in x264vfw settngs?
  4. --weightp 0
    The option might not be available in the vfw version GUI , you would enter that on the extra commandline box
    But ffdshow and mpchc decoders have fixed the issue with weightp, so it's unlikely to be the problem , assuming you are using recent build
    What dimensions are you encoding ?
  5. Originally Posted by poisondeathray View Post
    --weightp 0
    Format : AVC
    Format profile : High@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 8 frames
    Muxing mode : Container profile=Unknown@4.0
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 1h 33mn
    Nominal bit rate : 617 Kbps
    Width : 1 280 pixels
    Height : 544 pixels
    Display aspect ratio : 2.35:1
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.037
    Writing library : x264 core 93 r1542 5b86182
  6. 617 kbps is quite low for 1280x544 , it's likely contributing to these artifacts - especially if this is an action type movie with lots of motion , explosions etc..
    For a typical movie with those dimensions, most people end up with 4-5Mbps , you're using 6-8x less bitrate . x264 is efficient but not that efficient! Use a higher bitrate and/or preprocess with denoising filters to lower your bitrate requirements, or resize smaller
  7. Oh ok.
    Thanks for all your help.
