I have a Funia SV2000 WV10D6(model) DVD recorder/player. I have burned a few DVD's from my computer in DVD format and they won't play on the Funai unit. It just says Disk Error.
I am using a RW DVD+R 4.7 gb 1-16x disk for burning
I have researched the formats the unit should play, and according to the owners manual burning in a DVD format should play on the unit but it doesn't. I've tried to play it on another unit and I get video but no sound. don't know if that says anything
Any suggestions? Am I missing some type of format problem when I am burning the DVD?
Still works great on the PC after I burn it just not on the funai recorder/player
Results 1 to 14 of 14
What process did you use to make the dvds? It could be anything from failing to finalise the dvds to the brand of the blank dvd, or even the "+" or "-". The first things I'd do is try a different brand of blank dvd, and make sure it's being finalised. But since you indicated you are using rw discs, I try using a different brand of disc.
I used a video converter to convert the file to a DVD NTSC format. Than I used Windows media player to burn the DVD. And yes the WMP is finalizing the DVD.
If none of that is the issue, than what brand of DVD and what kind (R, RW, RWL) would you recommend? -
Being that your first attempt was unsucessful just a different brand. There has been many debates about the best to use and there is no concesus. I have no issues using Sony, TDK, Panasonic, or Verbatum. I mostly use +R, but have found that most older dvd players had better -R compatibility. I didn't catch if you said that you pc was playing them well.
I did not realise that Windows Media Player could burn a DVD disk ????????????????????
According to WMP in the burn menu you can select Data CD or DVD.
Since this seems to be a question, I might ask, what is the right way to get a downloaded file burned into DVD format so one can watch it by playing that file on your DVD player.
It appears that maybe I might even be going about this the wrong way. I assumed that you convert the downloaded file into something your DVD player can read and than burn it. However this appears to be the wrong way....I don't know. -
If you are simply using Windows Media Player and not Windows DVD Maker (that is for Vista and Win7) it can not make a standard DVD disk.
It makes a DATA disk which is simply the file you converted and burnt on to the disk. DVD players will only support certain formats such as Divx or Xvid. Anything that is not supported by your player will give an error. Your PC will play the disk quite fione as it just treats the disk like any other one and playes the file that you burnt in the player you chose supported by the appropiate codec(s).
To anser your question, we had a topic about this a few days ago. If you cannot find it, the simplest (and free) program to make a DVD disk guaranteed to play in your player is DVDFlick. -
Good luck with that.
But just ask yourself one question. The tools section of this site lists DVD creation programs costing between $0 and $1000(or more). It makes no mention of anything of this. You will not lose much by spending $25 but I would have thought that this website would have least given it a mention had it been worth it. -
I would expect that any program that calls itself DVD creation software would have to do that for the bare minimum.
My comment just relates to the simple fact that no mention of this is within the site and I would have expected that. So I just wonder whether it is a 're-badged' version of another program albeit an earlier version. Not unknown and one does seem to be getting a lot for your 25 bucks.
I can not comment on the actual program and have no use to try it myself already having several authoring programs costing between $0 and $300. Yet I am sure that the site would benefit from the experience of some actual use and its inclusion in the tools section.
Video files I add more for a burned disc won't read on my DVD recorder
By Indrek in forum DVD & Blu-ray RecordersReplies: 5Last Post: 8th Jan 2010, 08:30 -
burned DVD can't be played
By linda.0p in forum DVD RippingReplies: 2Last Post: 19th Sep 2008, 14:18 -
Can a SVCD video file be burned on to a DVD and played in a DVD player?
By dvdnewbie64 in forum Newbie / General discussionsReplies: 9Last Post: 17th Apr 2008, 21:44 -
no audio on iDVD-burned DVD when played on a standalone DVD player
By patroklus in forum MacReplies: 12Last Post: 10th Apr 2008, 13:56 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 18:59
