Hello, I am trying to transfer my old 8mm videotapes with my camcorder through the composite output on the camcorder and the quality is terrible. Here are some samples:
This is a sample of one of the tapes http://www.mediafire.com/?3h6eue22kv89cg4
This one is a live capture that I hooked up directly to my computer: http://www.mediafire.com/?02eux19ey456oxv
				Results 1 to 9 of 9
	if it has s-video out you might try that. --
	Could be dirty or worn heads. Does the video play properly to a TV?
 What hardware and software are you using to capture the video?Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
	The video looks the same on the TV and it cant be bad heads because I recorded that one thing live. And I use a hauppauge HVR-1600 capture card with wintv. And it is a sanyo standard 8 camcorder made in 1994.
	If it plays that way to a TV it is a camcorder issue not a capture issue. Recommends: Kiva.org - Loans that change lives.
	Yeah I'm thinking about buying a digital8 camcorder to digitize my tapes.
  Scripts and filters for an Opera (sample videos included)By jairovital in forum RestorationReplies: 317Last Post: 31st Oct 2011, 10:23
  8mm Videotape Playback issues on Sony VTRBy nazopo in forum MediaReplies: 1Last Post: 22nd Dec 2010, 20:47
  Need help in deinterlacing an old VHS converted video (Sample included) ..By ahmadka in forum RestorationReplies: 22Last Post: 30th Jun 2010, 13:43
  Help with Color Correction (Sample Included)By mlong30 in forum RestorationReplies: 9Last Post: 14th Mar 2008, 00:01
  Magnetized VHS - How to fix it? (Sample included)By djnice in forum RestorationReplies: 16Last Post: 18th Sep 2007, 14:14
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
