Looking for a list of hardware from 1-3 for fastest encoding results.
Currently my CPU average and RAM reads 60% (cpu) ~1.5GB Ram Usage.
going @ 150 FPS.
From this im assuming my cpu speed is slowing the whole process down?
MY specs, (srry i know i can add this in my profile but just made the account):
CPU: Intel Core 2 Quad 2.5GHz (Q9300)
RAM: DDR2 800MHz
Graphics: ATI Radeon HD 4600
MOBO: ASUS P5Q-PRO
Speed is not everything when it comes to video encoding. Certainly not where quality is concerned.
The CPU is, I believe, the most important item. Then comes the memory which should be matched to the MB. The graphics card does not normally play any part of that unless its own memory can be used AND the encoding program can make use of the GPU.Last edited by DB83; 11th Aug 2010 at 15:17.
What encoder are you talking about? Generally, CPU speed and number of cores/threads is most important. But some encoders don't make good use more than a handful of cores/threads.
Hardware issues in encoding
By videobread in forum ComputerReplies: 3Last Post: 23rd Nov 2011, 09:38 -
Hardware vs Software Encoding
By gabs247 in forum Capturing and VCRReplies: 49Last Post: 28th Mar 2010, 19:31 -
Hardware Encoding
By jeby1980 in forum Capturing and VCRReplies: 2Last Post: 21st Feb 2010, 23:03 -
Software or hardware encoding for project?
By stantheman1976 in forum Video ConversionReplies: 2Last Post: 11th Jun 2008, 15:53 -
TV tuner with hardware MPEG encoding
By mb508 in forum Capturing and VCRReplies: 7Last Post: 19th Sep 2007, 07:52
