THis is for my Philips Gogear Vibe SA2bve. I need to convert videos from whatever format, usually avi or flv, to mp4. The video compression was successful with Quicktime Pro and the Photo JPEG codec, although it was saved in .avi y renamed it to .mp4 and video worked fine in the mp4 player but it can't play the audio. Quicktime doesn't have the audio codec needed MS ADPCM-ACM (I put it wrong on the title :P I don't know if there is a way to add the audo codec needed to QT, or if may you know another software that can do the whole job with that video and audio codecs.
Thank you all.
d_d
Thank you, but the songbird application that came with the device doesn't have the function, otherwise I wouldn't be posting this thread... I even called Philips and they have no solution for this because they can't recommend any other software.
that's it -
Hi!
I had exactly the same situation, i.e. the Songbird included with Philips device had no video encoding feature. I've searched the Philips support/drivers page for an updated version of Songbird and found an edition for my device. This version includes video encoding feature. With that I've successfully converted and uploaded an 1:40 hours long Xvid movie to MP4.
You can also try the http://getsongbird.com/ for original Songbird if there's no Philips edition...
BR,
Junkie
M-JPEG codec
By cheerful in forum Software PlayingReplies: 1Last Post: 3rd Mar 2010, 19:43 -
does ffmpegx convert to photo-jpeg?
By martyw in forum ffmpegX general discussionReplies: 2Last Post: 14th Sep 2009, 20:18 -
Why TWO M-JPEG codec entries?
By terrypin in forum Newbie / General discussionsReplies: 2Last Post: 11th Jun 2009, 17:38 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 20:40 -
IMA ADPCM codec on vista
By TigerShark in forum AudioReplies: 0Last Post: 12th Dec 2007, 23:00
