Hi,
I'm kind of a noob to all this, so please forgive me if this is a stupid question or I've put it in the wrong place.
I have my pc connected to my television and usually back up dvd TS folders to a portable Hdd and play them from there through Corel Windvd 2010. This works fine.
But, I have noticed that the subtitles on some movies appear normal when on my monitor, but then turn green and illegible after I drag the player onto my TV screen. This happens, for example, with Lone Wolf and Cub: Sword of Vengeance, but not with Twilight Samurai which appears fine.
These are legit backups of commercial dvds made with clonedvd 4
Did you try the player's knowledge base?
http://corel.custhelp.com/http://milesaheadsoftware.org/
Fully enabled freeware for Windows PCs. -
Yeah, I've looked around there a bit. I finally mailed customer service. Haven't heard back yet. For now Media Player Classic seems to solve the problem. Probably should have tried that first. Thanks for the help
Anytime I see stuff about subtitles with bizarre colors I'm curious because so many times it seems like if I add .sup subtitles to anything I have to go in later and change the clut. Otherwise they will be neon pink. There's got to be some weird color space thing going on. If you find out anything please post back as I'm curious.
Runtime Error playing back ripped DVD folder
By oshanruiz in forum DVD RippingReplies: 0Last Post: 14th Jul 2011, 12:15 -
Playing Bluray with no certificate folder
By thor2j in forum Blu-ray RippingReplies: 2Last Post: 29th Mar 2010, 13:07 -
really screwy issue: PC will not read cdr-audio disc after it is burned
By mazinz in forum AudioReplies: 12Last Post: 1st Jul 2009, 00:38 -
playing .MKV file in MPC Home Cinema, no subs
By THX-UltraII in forum Newbie / General discussionsReplies: 1Last Post: 15th Aug 2008, 08:22 -
Nero Showtime playing from network folder ?
By Ian Huxley in forum Software PlayingReplies: 1Last Post: 1st Jun 2007, 13:40
