Hi All,
I'm opening a restaurant and have two 40" TVs to be used as displays for our menu.
I have 2 JPGs (the menu) which I'd like to have running all day long.
If I buy 2 DVD players, what exactly would I need to do to make sure that the images look right (proper resolution) and stay there all day long (DVD/TV doesn't go to sleep)?
Any help or direction would be greatly appreciated.
Thanks in advance,
Jeff
You may not even need DVD players. What are the TVs? Do they have built-in USB ports? That would be easiest.
Otherwise, get a cheap model of DVD player that has support for JPG files. I'd go for one that suports high resolution JPGs (1920x1080) or match the native resolution of the TV) has an HDMI out and slap the menus on a thumb drive. No DVDs or having to make movies required.Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/ -
You don't need two dvd players, you can use a HDMI splitter. I agree with neomaine that a USB or SD port would be best if your TV's have them. You could load several JPG's on them and use the TV remote to change the menu(daily special).
Thanks for the suggestion neomaine. I don't actually have the TVs yet, so not sure about the USB/SD port option.
MOVIEGEEK, I want the 2 TVS to each be displaying a separate image, so I don't think the splitter would work. And if instead of a dvd player I used a computer, a splitter still wouldn't work...right? I'd need two video outputs like VGA & HDMI. -
I've been using this HDMI splitter from Monoprice for a while. Works great. http://www.monoprice.com/products/product.asp?c_id=101&cp_id=10113&cs_id=1011301&p_id=...seq=1&format=2
Bingo! Get ones that have USB/SD ports that support high def JPGs! For something like this that should be fairly easy and relatively low cost. No wiring, no networking, no making movies.
Create the menu, save to high def JPG (or other supported format) to the thumb drive/SD card, stick in TV. Done.Have a good one,
neomaine
DVD Player doesn't play menu
By nharikrishna in forum DVD & Blu-ray PlayersReplies: 6Last Post: 21st Mar 2011, 06:48 -
How make auto-play jpg-foto-DVD for standalone DVDplayer?
By onidarbe in forum DVD & Blu-ray PlayersReplies: 1Last Post: 20th Oct 2009, 04:20 -
Looking for a way to prevent competitors commercials in my restaurant
By finchml250 in forum Newbie / General discussionsReplies: 4Last Post: 23rd Aug 2009, 02:08 -
Continuous play of root menu audio throughout all menu's
By breakbred101 in forum Authoring (DVD)Replies: 3Last Post: 28th Apr 2009, 19:37 -
JPG to AVI Back to JPG is it possible?
By concisa in forum Video ConversionReplies: 3Last Post: 11th Apr 2009, 10:06
