	Do you know the type of .avi -- as in the codec? DV? Xvid? Huffyuv? What? The .avi extension is just a container. We have to know more about the video inside the container. Could GSpot open the file at all?
 Also, from where did the .avi come? If it's a download, chances are it may be a fake video file.
	File Length Correct
 Multipart OpenDML AVI (2 parts)
 (186484 frames in first part, 24037 frames follow)
 Interleave: 1 vid frame (40 ms), preload=24
 Audio frames: Aligned on interleaves
 It's a download
 It also come up with
 MS A/V :
 partial render failure : following is the error reported by directshow:
 0x00040257 : [unknown]
 More specifically, the audio could be rendered, but the video could not:
 [src]-->>--[A]-->[avi splitter]>--[B]-->[MPEG-4 Layer-Decoder]>--[C]-->[Default DirectSound Device]
 Vid :
 [src]-->>--[A]-->[avi splitter]>--[B]-->[ffdshow Video decorder]>--[C]-->[Video renderer]
 failed to connect output pin 0x053c8634 ["stream00"] on AVI splitter to input pin 0x05c82724 ["in"] on filter
 0x0289567b["ffdshow Video decorder"]. ConnectDirect[] failed. Error: 0x80040207: [unknown]
	I had a similar problem with .avi files not opening in my video editing software. I had to download a avi to mpeg converter to be able to open them. http://www.youtube.com/user/TheCherryChurch#p/a
  How to make Media Player Classic's window size stay the same when playing mBy DigitalAbstracts in forum Newbie / General discussionsReplies: 5Last Post: 28th Jun 2016, 20:35
  SOLVED: Media Player Classic - playback picture too dark......By bahjan in forum Software PlayingReplies: 0Last Post: 17th Nov 2010, 06:32
  No Sound When playing MKV files in wmp or media player classicBy tmiller_15 in forum Blu-ray RippingReplies: 2Last Post: 13th Jun 2009, 00:24
  no sound in some avi's with Media Player ClassicBy DraWing in forum Software PlayingReplies: 10Last Post: 26th Feb 2009, 00:29
  settings for classic wmpBy greendesert in forum Software PlayingReplies: 4Last Post: 17th Dec 2007, 19:04
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
