Hi All I am going crazy here, I have been trying to get the compete file into fcp of for more hours that I would admit.
I have a MPEG 4 video file originally from a convergent NANO. I can play the whole clip 13.40 mins on VLC no problem, but as soon as I try to convert in Slipstream or qt7 or compressor none of them can see more than 30 seconds of the clip. So they convert 30 seconds of the clip and no more any suggestions very welcome the original file is about 3.7 gig of material shot on a SOny Ex1![]()
No google cannot find the downloads on this site, IF I do manage to get hold of it what do I do with it ? its a codec right ?
Hi there , is it mpeg2 in mp4 container ? like xdcam native footage ? you can use mediainfo mac to check
ffmpeg is a command line utility that is crossplatform, available on pc/max/linux . For this, all it's doing is re-packaging the contents into a .mov container, which is more compatible for mac platform , and fcp
Here are instructions for almost the same thing, but I'm not sure if the batch method will work on a mac:
https://forum.videohelp.com/threads/323517-Rewrap-MP4-to-MOV-files -
hi thanks, poisiondeathray ! will try 'media info as the ffmpeg was a non runner sadly
Converting .dv and .mov Mac file to MPEG-2 No Audio
By RL in forum ffmpegX general discussionReplies: 3Last Post: 30th Jan 2011, 06:47 -
Converting .mov or .avi to flv does not work
By Alainb2809 in forum ffmpegX general discussionReplies: 22Last Post: 11th Oct 2010, 14:33 -
Converting MOV to MPEG-2 File
By cyberboy in forum Video ConversionReplies: 5Last Post: 16th May 2009, 18:39 -
Converting MOV -> MPEG-2 (or AVI or...)
By Sean-PH in forum ffmpegX general discussionReplies: 5Last Post: 10th Jan 2008, 14:35 -
problem converting one little file to mpeg MOV (any ideas why)
By bdaul in forum ffmpegX general discussionReplies: 5Last Post: 1st Jan 2008, 09:32
