Gents!
I'm seriously considering upgrading to Premiere Pro CS4 and buying a new 64-bit computer with windows 7 as I shifted from SD to HDV in the last month and a half. Being enabled to borrow an A1 on weekends for several weeks has made me a fan of it and HDV in general. However, the combination of CS3, 32-bit Vista Home Premium and a Intel Core Duo chip just wasn't cutting it so I need advice from those who have traveled this road before. There are certainly budget considerations in this decision so I'm hoping to find a viable solution that is reasonable.
Archiving from the master timeline to mini dv tape with the above was & still is sheer luck!
I want to find the right processor/CPU/motherboard for the job.
For example: What does AMD have that will cut it? Anything? Is Intel better than AMD?
Is there a website that lists the "pecking order" in processors, what specifically will work with PPro CS 4 & what a reasonable price is?
Just out of curiosity, will CS3 still launch on a 64 bit only OS?
How do I find out what processors other than Intel are up to the challenge to drive HDV on CS4 or even 3 for that matter?
Thanks for any insight, comments and recommendations on this topic!
Looking forward to hearing from you
I put together a six core AMD PC a while back and it performs very well. I mostly use it for Blu-ray to MKV, and that requires a lot of CPU power to speed things up. https://forum.videohelp.com/threads/270162-AMD-six-core-CPU-and-Corsair-H50-water-cooli...hlight=corsair It was a lot cheaper than a similar Intel CPU.
Not sure about 64bit OSs. I still use 32bit OSs except for my laptop. -
I use Premiere CS3 in Vista 64, works fine. Have a project open right now, in fact.
Here's some CPU benchmarks .....
http://www.tomshardware.com/charts/2009-desktop-cpu-charts-update-1/benchmarks,60.html
CPU Usage "XviD 1.3.2"
By Zangetsu in forum DVD RippingReplies: 6Last Post: 6th Feb 2012, 09:34 -
CPU temp "alert"
By Edgarke16 in forum ComputerReplies: 2Last Post: 20th Feb 2011, 18:44 -
5.1 mix gone wrong. Did the "pros" do a poor job?
By takearushfan in forum AudioReplies: 33Last Post: 21st Nov 2009, 21:34 -
VDub "add to job control" option...not there anymore?
By CursedLemon in forum EditingReplies: 2Last Post: 17th Nov 2009, 10:47 -
"Sicko" on YouTube An Inside Job Says Michael Moore
By Vid-Kid in forum Off topicReplies: 20Last Post: 21st Jul 2007, 18:46
