Using mkvmerge to split files at x position in the video. So that way 6 or 7gig file would fit nicely on two dvd5. If I use mkv2vob to split automatically, obviously won't split at a "logical" position. Could be halfway through a scene or dialog....
If I convert to mpg (automatic file format option), then the large file splits and remuxes without issues. But if I use mkvmerge to split the file where I want it to be split. Then send one or both files through mkv2vob, it will say reparing ac3 and shortly afer txmuxer crashes. So reparing acs status changes to Muxing failed.
The dts files seemed to work, but the ac3 files are the ones having and issue. Do I need to check off another option? Or is it just being a piece and I should invest in dual layers?
Results 1 to 1 of 1
problems splitting mkv files then playing on lg blu ray
By julie_152 in forum Video ConversionReplies: 6Last Post: 15th Jan 2013, 06:54 -
Problem splitting mkv files
By Sennaista in forum Video ConversionReplies: 8Last Post: 5th Jul 2012, 22:57 -
Splitting AC3 48Hz 2 Channel into 2 seperate files
By Caliburner9 in forum Newbie / General discussionsReplies: 3Last Post: 10th Jan 2011, 23:51 -
Splitting AC3 Into Seperate Files
By travelagent73 in forum AudioReplies: 4Last Post: 19th Aug 2009, 14:46 -
Reparing or fixing AVI files
By 1234567 in forum EditingReplies: 26Last Post: 16th Feb 2009, 18:53
