Hi,
I've got several VOB files that I've processed from DV captures. Now I'd like to burn them as DVDs without the inclusion of Menus or Chapters.
Is there a software out there that will do that for me.
By the way, I searched the forums and was unable to find any info about doing this.
Thanks for any help that's offered!
Cheers,
Fred
Why do people create VOB files out of context ?
VOB files should be the result of the authoring process for creating a DVD. This ensures that they are DVD cimpliant, and also makes sure you have all the associated files required to create an actual DVD. Encoding with some one-click wonder like SUPER (or xilisoft *shudder*) et al directly to VOB gives you two things - poor quality output and useless files.
As for no menus/no chapters - again, this is a function of authoring. You choose what features you want, and author accordingly. Even relatively one-click front-ends like AVStoDVD and ConvertXtoDVD allow you to create a DVD with no menu or chapters.
If your current VOB files are actually DVD compliant, you could try DVD Styler or GUIforDVDAuthor to author a valid disc. You may have to demux the files first however.Read my blog here.
As was mentionned, your VOB's should be DVD compliant if you want them to play on a DVD player. You can "author" a DVD from your VOB's with IFOedit. Then you'll have to burn the disc with software that can do UDF format, the burning function in Windows won't work. You should have a burning program like Nero, Roxio... If not use the free IMGburn. When you go to the download page for those programs look at the bottom of the page for guides.
Burning a dvd so that it keeps the orignal menus/chapters..
By Dchristy47 in forum Newbie / General discussionsReplies: 3Last Post: 29th Jul 2010, 02:11 -
how to make 3 vob files into a DVD with chapters
By c1steady in forum Authoring (DVD)Replies: 8Last Post: 3rd Oct 2009, 05:46 -
Program that allows direct VOB burning AND menus
By 6079 in forum Authoring (DVD)Replies: 8Last Post: 22nd Jul 2009, 05:15 -
problem with menus when burning VIDEO_TS files to DVD
By samd292 in forum MacReplies: 3Last Post: 24th Jun 2008, 08:49 -
VOB editing before burning (splitting, chapters, etc)
By windranger in forum Newbie / General discussionsReplies: 7Last Post: 3rd Nov 2007, 08:29
