I have video I've captured from a Digital8 camcorder as DV AVI. I downloaded avi2dvd and when I first tried to load the dv_avi file it wanted to convert it, so I said ok. It said lossless conversion to an avi format that avi2dvd would support and when it was done it was about the same size file but would now load into the program.
Great.
Except not. I used pretty much everything from the first 3 tabs of the afterdawn tutorial (didn't need the rest) and submitted the job. It "completed" a little while later with the following error in BeSweet_AudioStream 1 AC3 2CH.ac3.txt
Error 32: No input-data was found (wrong substream?)
Quiting...
[00:00:00:000] Conversion Completed !
The file Avi2Dvd_Log.txt had this in it:
Quiting...
Any pointers as to what went wrong, either in the capture or the dv to normal avi conversion? I captured as avi typeII I believe, though it's been long enough now that I can't be absolutely certain.
Thanks.
Results 1 to 1 of 1
avi to dvd error
By psy93 in forum Video ConversionReplies: 10Last Post: 6th Jul 2010, 12:32 -
DVD FLick Audio Encoding Error on AVI videos produced by Canon camera
By patplh in forum Authoring (DVD)Replies: 18Last Post: 14th May 2009, 19:58 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 16:38 -
Converting vfr-avi to cfr-avi that produced error in picture.
By Jo The Veteran in forum Video ConversionReplies: 27Last Post: 2nd Aug 2007, 00:41 -
Joining 2 avi files, error with audio streams, need help
By leinan in forum Newbie / General discussionsReplies: 5Last Post: 8th Jul 2007, 07:12
