Have an xvid (of a vhs tape) which has occasional bend/slant at top edge of screen. I'm going to IVTC it, and would like to fix the slanting if possible. Any recommendation for best filter?
If it was captured with a tension slant in the digital video, some of the line info is missing.
http://www.kiva.org/about -
You have to redo this in hardware, starting with the tape. Software can't fix this.
There are a couple of filters that might be useful:
Rotate: http://avisynth.org.ru/rotate/rotate.html
Rotate plugin rotates or shears frames on any given angle.
Spinner: http://avisynth.org/vcmohan/Spinner/Spinner.html
Spinner plugin rotates a frame or selected part of it about the given axis coordinates.
How to Fix Horizontal Jitter with AviSynth?
By VideoFanatic in forum RestorationReplies: 2Last Post: 26th Jan 2014, 23:52 -
Avisynth filter RemoveDirt not doing anything
By ThePhoenix in forum Newbie / General discussionsReplies: 10Last Post: 4th Mar 2012, 19:40 -
AviSynth and Filter Order
By sambat in forum EditingReplies: 3Last Post: 11th Jan 2012, 11:04 -
Need Avisynth filter
By fubuki81 in forum RestorationReplies: 5Last Post: 30th Sep 2008, 14:04 -
Logoaway filter for AviSynth?
By DRP in forum Video ConversionReplies: 2Last Post: 8th Aug 2008, 05:30
