I cannot save any of my movies in Virtual Dub with compression. This only thing that works is "Uncompressed." Otherwise I get the error -
"Cannot initialize smart rendering: The selected video codec is able to compress the source video, but cannot match the same compressed format."
If I choose "Video" / "Compression" from the menu I have several things to choose from: Uncompressed, Cinepak, ffdshow, XVid, Microsoft RLE, among others. But I get that same error when trying to save as AVI no matter which I choose - except for Uncompressed.
Oh yes, when I uncheck "Smart Rendering" it works fine. I guess now I want to know why I should or shouldn't try to use Smart rendering.
As was pointed out you need to use the same codec as the existing video if you want to use Smart Rendering. File -> File Information will tell you what codec is used in the currently opened video file. Note that this won't work with some sources -- an MPG file, for example.
You use Smart Rendering when you want to trim out small pieces of a video without reencoding most of it. Only cut GOPs are reencoded. This is why the compression codec needs to be the same as the source. You can only use one codec through the entire video.
virtualdub cropping/compression error?
By popoxDDD in forum Newbie / General discussionsReplies: 4Last Post: 28th Mar 2011, 21:32 -
Saving multiple AVIs from 1 AVI by virtualdub script
By DveD in forum EditingReplies: 1Last Post: 16th Oct 2009, 08:47 -
VirtualDub: Saving Segmented Avi
By Ruro Jiruries in forum EditingReplies: 0Last Post: 18th Jun 2009, 07:13 -
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 20:18 -
VirtualDub error while saving with subtitle on
By ajumma in forum SubtitleReplies: 0Last Post: 3rd Jun 2007, 01:35
