Hi,
Maybe this will sound odd, but I would like to know if there is a way of exporting x264's --help, --longhelp or --fullhelp to a text file that I can search, highlight and read more comfortably than I can in the command prompt (Windows). As it may be obvious by now, I seldom use the windows command prompt for anything, and I can't even get started tinkering with x264 because of that.
I have triedbut this saves the man page in a barely readable unformated file (I guess all tabs, line breaks and multiple spaces were saved as single spaces).Code:x264 --help > x264help.txt
I know there are good Linux tools for that, but my lab is Windows only.
I have attached them.
You should be able to view them in notebook or whatever. -
You can read it with wordpad, instead of notepad to keep the formattingbut this saves the man page in a barely readable unformated file
Thank you both, bat999 files are identical to mine. Wordpad's tabulation is a lot easier to read.
I had no idea wordpad and notepad interpret txt files differently.
Do most people read man pages directly from the console?
Converting XPI file to something readable
By NP11073 in forum Video ConversionReplies: 1Last Post: 24th May 2010, 14:25 -
x264 log file
By txporter in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2010, 15:40 -
Bitrate of avi file and x264 file
By maass in forum Newbie / General discussionsReplies: 8Last Post: 9th Apr 2009, 07:27 -
convert x264 HDxT file to ps3 playable file
By yodaddi in forum Authoring (Blu-ray)Replies: 3Last Post: 25th Mar 2009, 21:02 -
converting .DAT file to readable jpeg
By illyad in forum ComputerReplies: 4Last Post: 23rd Oct 2007, 04:14
