Hey just wanted to know is there a way to make a single 3gig vob Created with xilisoft vid converter a bnch of dvd ready 0.99 gig vobs and with ifos and vobs ??
Step one - stop using crap like xilisoft.
Step two - try AVStoDVD, which will happily vonvert your file using a high quality encoder (HCenc), then author a disc ready for burning
Step three - burn the results with imgburn
As for your current problem - try GUIforDVDAuthorRead my blog here.
gunsling, i just wanted to know cause i use dvdrebuilder pro to comp[ress huge size movies and convertxtodvd to do standard conversions and dvfab to backup my original dvds so i know that xilisoft is not the best but it's quick and sometimes i need to convert to flv or back to avi and really don't want to different apps just to convert to 20 differrent filetypes , if you have a better alround converter let me know , thanx for your advice on AVS ill give it a shot
You already have ConvertxtoDVD, so why do you need Xilisoft ? It will handle all the formats Xilisoft will and authors a compliant disc for you.
As for all rounders - I prefer Xvid4PSP, and if I need a quick and dirty, Any Video Converter FreeRead my blog here.
Thought I'd put in a good word for XMedia Recode,
I like it because it offers Xvid CQ mode.
https://www.videohelp.com/tools/XMedia_Recode -
Is there any great allround converters? and can some one tell me is xvid4psp 5 or 6 better
I prefer Xvid4psp 5.0.36, although I am finding the beta version 6 is getting better. I still prefer to use a dedicated avi to dvd converter (I use AVStoDVD mostly) for quick DVD authoring, and a proper encoder and separate authoring tool for more complicated work. For other format conversions Xvid4PSP does me just fine.
Read my blog here.
Single .VOB file into working DVD?
By AHK in forum Authoring (DVD)Replies: 14Last Post: 5th Sep 2011, 12:38 -
Need to make IFO, BUP for Single VOB
By Simmons in forum Authoring (DVD)Replies: 5Last Post: 28th Aug 2011, 21:15 -
several VOB files to single file (mp4)
By smondal29 in forum DVD RippingReplies: 1Last Post: 24th Jun 2011, 04:23 -
DVDFab Platinum - rip into single Vob?
By nrishiraj in forum Authoring (DVD)Replies: 1Last Post: 19th Dec 2008, 18:33 -
Single vob file in MacTheRipper?
By bmoney017 in forum MacReplies: 2Last Post: 20th Oct 2007, 03:07
