I've been making SVCDs with tmpgenc for a while now and the picture quality is great but the audio kinda sux. It's not bad I guess, but I always get a bit of noise (sort of like a low hum or buzz) in the audio stream that bothers me (especially when I'm wearing headphones). I also tried toolame to encode the audio but I'm not really happy with that either. I get the same sort of noise. Any suggestions? Or am I just being anal?
Any advice would be appreciated.
Oh, by the way I always encode the audio at 192 kbps or more.
Thanks.
My favorite MPEG-1 audio encoder is QDesign's I-media MPEG audio pro. I believe, it is not for sale anymore, so you have to do a little google search. Also, do not use TMPG's built-in downsampler. If you need to downsample 48->44,1 kHZ, use ssrc or one of the pro audio editors.
Thanks for the advise Truman. I'll try getting a hold of QDesign's I-media MPEG audio pro.
Well, I acchieve kinda good quality by doing like this (if you rip from DVD):
1. Extract the desired AC3 file from the DVD (You should use the Dolby Digital 5.1 stream, if available)
2. Use Azid to generate a wave file (apply Dynamic Range Compression, mix the subwoofer channel with -2db in the Left/Right Channels and use Surround output).
3. Use SSRC to downsample from 48KHz to 44.1KHz and to get even better quality try 2-pass mode, it will take considerably longer but eventually you get a better downsampled wave file.
4. Use the latest tooLame to make a 192 or 224kbit MP2 file, use the error protection and the stereo mode switch to get a good quality MP2 file.
The MPEG 1 Layer II Audio file will by many many times better than the once TMPGenc generates. Just test and enjoy!
PS.: I know that there is a tool called BeSweet which does all of this but instability issues held me from using the tool. Also: When you do it yourself you at least know what you've got.SiCN - the real one!
"Dudes, we gotta think here... What would Brian Boitano do?"
Encoding .Avi to Svcd?
By mrjust in forum Newbie / General discussionsReplies: 4Last Post: 16th Jan 2011, 14:40 -
AVStoDVD crashed on audio encoding.. have m2v video file, but no audio
By arcooke in forum Newbie / General discussionsReplies: 3Last Post: 5th Aug 2010, 15:18 -
Encoding VIDEO_TS to mpeg-2 SVCD
By phamtom in forum ffmpegX general discussionReplies: 6Last Post: 27th Apr 2008, 16:05 -
error encoding while converting avi to svcd
By joannekhow in forum ffmpegX general discussionReplies: 4Last Post: 1st Oct 2007, 12:41 -
Burning VCD/Svcd mpg files to dvd without encoding
By Morb1ous in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 17:56
