I'm trying to make a slideshow with DVD slideshow GUI v.0.9.3.8 on Windows XP. The problem I am running in to is that I enter an animation for one slide some other (random ?) slide gets the same animation. When I remove it from that other slide it also gets removed from the slide I wanted to put it on...
Am I doing something wrong or is this a bug?
Regards,
Wim
Results 1 to 1 of 1
How to edit video to add slides into it
By m.azza in forum EditingReplies: 0Last Post: 15th Sep 2011, 10:11 -
Quality of slides
By marklewis in forum Capturing and VCRReplies: 2Last Post: 2nd Aug 2010, 20:43 -
Network Attached Storage
By igeekus in forum Media Center PC / MediaCentersReplies: 1Last Post: 31st Aug 2009, 13:58 -
Scanning 35mm slides?
By videobread in forum ComputerReplies: 1Last Post: 7th Sep 2007, 11:45 -
How to capture 35mm slides
By avz10 in forum Off topicReplies: 11Last Post: 29th Jun 2007, 18:52
