Yah, so the configging ffdshow don't work, and I suspect it's because of rundll32.exe since I see that one trying to run in ProcesExplorer
So:
1. Are there other ways of configging this?
2. If not, how do i run rundll32.exe? I guess there's some protection/anti-virus program preventing this, or something.
Looking for subtitles of: Höök tt0997023, Lime tt0269480, La clé sur la porte tt0077348. tt=iMDb.com Found Desideria tt0081724 subtitle! :-)
1: ffdshow Audio decoder configuration
Target: C:\WINDOWS\system32\rundll32.exe ffdshow.ax,configureAudio
Start In: "C:\Program Files\ffdshow"
2: ffdshow Video decoder configuration
3: ffdshow VFW configuration
Target: C:\WINDOWS\system32\rundll32.exe ff_vfw.dll,configureVFW
Rundll32.exe :
The rundll32.exe process is responsible for running DLLs and placing its libraries in the memory. The rundll32.exe process is known as a command line utility program, and it performs its embedded functions along with the rundll.exe file. Rundll32.exe works by invoking a function that is exported from a specific 16-bit or 32-bit DLL module. However the only DLLs that you can call with the rundll.exe and rundll32.exe files are the ones that are only specified to be accessed by these processes.
Anything beyond this is considered suspicious -
Do ffdshow icons appear in the Tray when you play a video? You can configure ffdshow from them. Or open GraphEdit, insert the ffdshow Decoder Filter and config from there. Or play a video with MPCHC (you may have to disable MPCHC's internal decoders to get it to use ffdshow), right click on the window while it's playing and select Filters -> ffdshow video decoder. Or open VirtualDub, select Video -> Compression... select ffdshow Video Codec, press Configure.
Note some of those will configure the DirectShow filter, some the VFW filter. -
@BJS: thanks, but Rundll32.exe just doesn't run at all. do u have other ideas?
@ jagobo: there's no system tray icon when i play videos.
but the configging in Vdub works, or seeems to, i see a "ffvfw MPEG-4 Codec" option.
I will reboot and report back later. thanks.Last edited by KneeRow; 9th Aug 2010 at 09:20.
Looking for subtitles of: Höök tt0997023, Lime tt0269480, La clé sur la porte tt0077348. tt=iMDb.com Found Desideria tt0081724 subtitle! :-) -
Configuring via VirtualDub will configure the VFW portion of ffdshow. It will have no effect on the DirectShow portion -- which media players will use.
well, crap
FFDShow and vmr9 with overlay color controls no longer work. Please help
By mces97 in forum Software PlayingReplies: 0Last Post: 30th Jan 2011, 15:57 -
ffvdub or ffdshow encoder image processing doesn't work with VirtualDub?
By Milardo in forum EditingReplies: 42Last Post: 21st Jan 2011, 19:09 -
Cannot find c:\windows\system32\rundll32.exe
By BLSAMPLES in forum ComputerReplies: 23Last Post: 14th Jan 2011, 15:14 -
how do I install x264.exe to work AND to work with Lemings GUI?
By Krelmaneck in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2010, 23:13 -
Encoding ( hardsubbing) doesnt work with ffdshow
By lovemusic in forum SubtitleReplies: 2Last Post: 5th Mar 2008, 15:37
