Hi Chrissyboy,
I have noticed that when I open an existing SVCD2DVD project, the Button Text (and thus my menu) changes to the overall Titleset Name (as if the broken chain button had not been clicked). If there are multiple movies in the project, the problem occurs only on the first movie; the rest are fine. This is an entirely repeatable problem - it makes no difference what projects I work on.
Another issue I noticed is than when the programme is minimised, and it has completed it's task, and the mouse is hovered over the football icon, it reports "Encoding menu...Done 50%" when in fact it is done to completion.
Any thoughts?
Thanks for your great work on this software!
Dan
	Danno - i can't replicate this. What build are you using? SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
	Hi ChrissyBoy,
 I'm using 2.5.5030.
 Attached are two log files. The first is before the project has been saved and the second is after the project has been saved. You can see that in the second log file (after saving), the first button text becomes the movie name. In this case, "Presents" becomes "Christmas".
 Thanks for looking into this for me.
 Danno
	I have made a fix for you to test. Can you email me? SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
  Handbreak Will Not Recognize Some Titleset's When Converting DVD to IPodBy kpoman in forum DVD RippingReplies: 0Last Post: 9th Sep 2008, 10:49
  DVD Architect Studio 4.5 Titleset RestrictionBy luigi2000 in forum Authoring (DVD)Replies: 2Last Post: 8th Sep 2008, 23:05
  Vegas is rendering frames it shouldn'tBy tripecac in forum EditingReplies: 9Last Post: 16th Jul 2008, 13:26
  Creating Titleset #1 freezingBy bjproc in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 5th Oct 2007, 10:47
  titleset blanker w vob 'viewer' ?By gazix in forum EditingReplies: 4Last Post: 2nd Aug 2007, 13:19
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
