This is maybe a very silly question: how to use the job control function? I don't know how to add and edit jobs in the job control window.
I just have bought a TV-Wonder and record TV programs by Intervideo's WinDVR. Using MPEG-1 format, 6400K/s, the quality is good enough for me.
But the program automatically cut the recorded file if the file is larger than 4GB. So when I compress the MPG file into Divx format, I have to work on two files. I hope I can use the job control function to save some time.
Thanks.
ps: My computer: Atholon 1G/256MB PC-133 SDRam/SIS735 Board/IBM60G(60GXP)
capture into avi format, picview mjpeg at 18 or 19 quality setting would give better results than the mpeg for video with relatively the same size or probably smaller.
then if it splits the file, you can append the second file with virtualdub into one editable file, as long as they were captured with all the same parameters (framerate, audio, video size etc.)
when you edit a file, you press save and click add to jobs
then you open the jobs and start the jobs whenever you want.
if you want to save the file and re-edit it later, you have to save the processing settings when you are done editing and then load the processing settings again to re-edit. once you add to the jobs, you cannot re-edit the job. -
one prob though.. either i was mistaken or he changed it or hopefully removed the option so I dont think im going nuts. I tried a save and reopen for a file today and didnt work. so guess there is no way to re-edit a edited file once you close virtualdub.
VDub "add to job control" option...not there anymore?
By CursedLemon in forum EditingReplies: 2Last Post: 17th Nov 2009, 09:47 -
virtualdub don't run this job--->disappeared
By spartankid in forum Video ConversionReplies: 2Last Post: 14th Nov 2009, 22:09 -
Virtualdub batch job changes filter settings back to default. Bug?
By gll99 in forum Video ConversionReplies: 5Last Post: 5th Apr 2009, 22:41 -
Selectable Output Control - MPAA's new control tactic
By akrako1 in forum Latest Video NewsReplies: 2Last Post: 7th Aug 2008, 21:05 -
VirtualDub job scheduler
By chrisr34000 in forum EditingReplies: 2Last Post: 25th Jan 2008, 17:07
