Hi ... Could someone suggest the easiest program to burn photos with music in the background onto a cd disc. I like to burn onto a disc some pics I have and have it load as a slide show with music in the background . I never done it before I'm curious to know how its done . I'm using windows xp pro
Make a VCD, DVD slideshow? DVD slideshow GUI, Foto2Avi, Photodex Proshow, etc.
Thanks so much ... I'm curious out of those 3 which one would you say is the easiest to use ? Its for a friend and he a very novice user with computers ...
You have to answer Baldrick's question first.
Where is your friend going to be PLAYING this slideshow? You mention CD. Is this for playing using a DVD Player and a television or for playing using your computer? The two answers make a big difference.
If you are showing on a TV then you have to make a video file, convert it to the DVD standard, and then burn it on a DVD (let's be honest, CD-media support on DVD players is just not something you can trust anymore).
If you're using your computer then you might just use Picasa. It will make a Windows compatible "Gift CD" with a slideshow program on it that autoruns when you put it oin the computer. Super easy for the novice (and it's free). But, that disk will NOT work in a DVD player. -
He want to put pics and music on a cd or dvd disc , than have it playing on a DVD Player on his TV .
Thanks -
You can find DVD slideshow GUI tutorials here:
http://download.videohelp.com/tin2tin/tutorials.html -
Myself I never had the need to do such though I did try out DVD Slideshow and I believe its exactly what my buddy could use . It was pretty easy to use for me as a first timer .
Thanks everyone
How to play pics adjusted on a PC to a TV ?
By DBenz in forum Software PlayingReplies: 3Last Post: 3rd Jun 2011, 01:38 -
Music Play Over Voice Separation Info Please?
By Teac23 in forum RestorationReplies: 1Last Post: 2nd Feb 2010, 08:23 -
I would like to set up something to just play music, need help!
By Lothar1974 in forum Media Center PC / MediaCentersReplies: 3Last Post: 31st Oct 2009, 09:07 -
htpc play music video software
By scorpio1959 in forum Software PlayingReplies: 2Last Post: 5th Jul 2009, 07:00 -
How do you play music on the computer using all 6 speakers?
By Obamargarine in forum ComputerReplies: 5Last Post: 10th Mar 2009, 17:40
