I have difficulty playing some AVI and DIVX files on this player using a USB stick (FAT 32)
It recognises and plays perfectly, files of about 700Mb file size but fails to play
for example a few converted files (avi and DIVX) which are over 2Gb file size.
The menu brings up the title of the movie but will not play it.
I suspect there is a maximum file size when using USB but there is no mention of
this in the manual.
Can anyone please confirm whether there is a maximum file size when using USB
If so, I can only think of one way around the problem and that is to split the
files up in which case can anyone please recommend suitable software for
doing this.
Thank you for your assistance
Most Divx/Xvid enabled players will not play files over 2GB. You can split them with AVI Demux or Virtualdub by removing the half you don't want and saving the rest, then repeating for the other half. Or encode to fit under the 2GB limit.
Read my blog here.
Thanks very much for the information and the prompt and detailed reply
I will report back with my result
Thanks again
Phillips DVP 3360
By smiggyballs in forum Newbie / General discussionsReplies: 2Last Post: 24th Apr 2014, 12:14 -
Philips DVP 5990 USB question
By Estam in forum DVD & Blu-ray PlayersReplies: 2Last Post: 6th Dec 2010, 14:20 -
USB Problem with Philips DVP 5990
By bufbt in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2010, 12:52 -
Connecting USB harddrive to Philips DVP-5990/37 player
By DVantrease in forum DVD & Blu-ray PlayersReplies: 12Last Post: 12th Aug 2009, 19:30 -
Philips DVP 5960, compatible USB Key List
By phunkyfish in forum DVD & Blu-ray PlayersReplies: 49Last Post: 30th Sep 2008, 10:18
