For starters, I can connect my laptop up to my telly with an HDMI to DVI cable.
I only see an HDMI out on my laptop and my DVD recorder isn't HD. I could have bought an HD one but the thought of the size after recording put me off. Plus I don't care if it's not HD anyway.
Any way to do it using HD cables?
Edit: Want to hook the laptop up to a telly and then record it with an external recorder (in this case a DVD recorder)
Edit again. 1 more thing; The DVD recorder has 2 HDMI slots at the back along with component slots, etc
If your laptop has VGA output you can get an inexpensive VGA to s-video/composite scan converter. HDMI/DVI to s-video/composite is much more expensive.
S-video and composite resolution is far less than any computer display. About 640x480. Desktop text will not be very readable:
https://forum.videohelp.com/threads/283861-VGA-to-S-video?p=1756748&viewfull=1#post1756748 -
I hate how you need this and that. I thought DVD recorders simply recorded what was on screen. I thought you just connected your DVD recorder to anything that produces a picture (IE the telly) and that would be it (IE it would record anything that produces a picture connected to it). DVD recorders really are awkward and crap and a complete waste of money. Or are they deliberately designed this way for legal reasons? I've got enough cables as it is man!
An old VCR is better!
Edit: You go out and buy a DVD recorder (it says recorder!!) and yet you have to buy these weird cables just to record things!Last edited by xtube; 8th Aug 2010 at 21:27.
DVD recorders only record standard definition video (much like a VCR), not high definition video or computer output. DVD only supports standard definition too.
SNES was standard definition and used the same standard def cables as other standard def devices.
What about usb? My DVD recorder has 1 usb slot. Is there any way I might be able to capture the computer screen that way?
Edit: It has 2 ways of connecting to a PC, a small usb and the normal usb.Last edited by xtube; 11th Aug 2010 at 12:57.
Newbie - Laptop to DVD Recorder
By Calamity in forum Newbie / General discussionsReplies: 1Last Post: 9th Jul 2011, 21:22 -
Connect Laptop to DVD/HDD Recorder
By HamishT in forum DVD & Blu-ray RecordersReplies: 5Last Post: 2nd Apr 2011, 23:58 -
Record from laptop onto home DVD recorder
By Tbag in forum Newbie / General discussionsReplies: 9Last Post: 26th Jan 2010, 18:36 -
Hooking a laptop to a dvd recorder
By WitchfinderGeneral in forum Newbie / General discussionsReplies: 1Last Post: 21st Aug 2007, 14:46 -
can i record laptop video to standalone dvd recorder via firewire?
By beatz2005 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 17th May 2007, 09:54
