  1. Member doppletwo's Avatar
    Dec 2004
    United States, Earff
    How many times can you write to a BD-RE disc? Is it ever less than 100 with careful use? Anyone here ever done 500 or 1,000 writes to the same disc?
    I am trying to cut down on blu ray media usage at work, so I switched to BD-RE from BD-R. So far they are working out, but how many writes can I actually expect out of these discs?
    Even if I can only get ten writes per disc the savings are well worth it.
    snappy phrase
    I don't know what you're talking about.
    Some die after one use. Some can last for thousands.
