I often d/l clips from youtube and other sites, using Firefox and a download helper. I usually have three audio problems: too loud or soft; not in sync with the video (sometimes a second or two off); and background rumble or buzz. All these problems are inherent in the clip, not originating in FF or the download helper.
Any suggestions for programs, preferably freeware, to deal with these problems? I have Cool Edit Pro as an audio editor, which I could use to record in real time (that is, a 60-minute clip would take 60 minutes to record) the sound track, then adjust volume and remove background garbage, but I don't know how I would replace the original track with this one, and sync it with the video.
Thanks,
Ray
I should have added that the audio is out of sync by a constant amount for the duration of the clip.
audio lag in .mov to .flv converted files
By french-petzouille in forum ffmpegX general discussionReplies: 5Last Post: 3rd Mar 2012, 13:05 -
no audio in flv files with gom player
By rocketman122 in forum Newbie / General discussionsReplies: 3Last Post: 7th Jul 2011, 00:47 -
How to fix uneven audio volume in MKV/MP4/AVI files?
By ConverterCrazy in forum RestorationReplies: 5Last Post: 19th Jul 2010, 00:26 -
Multiple FLV files into 1 big FLV file, how??
By vividbreeze in forum Newbie / General discussionsReplies: 1Last Post: 16th Dec 2008, 16:11 -
How to fix/repair FLV video?
By misterbean in forum Newbie / General discussionsReplies: 1Last Post: 11th Mar 2008, 01:51
