After two repairs to my ES15 I purchased a used ES25 unit hoping that with the fan it would last longer that 6-10 months. My mistake, after a simple recording session I got the U99 error that the unit was not operating properly. It followed up with a U61 error message that is now in a continuous loop of screen messages "There was a power failure or the AC plug was disconnected while the unit was on. The unit is carrying out its recovery process. This process restores the unit to normal operation. The unit is not broken. Wait until the message disappears.".The screen prompts will not produce a "fix". Does anyone have any ideas that do not include sending it back to Illinois or Texas for repair? That is a mistake that I would soon like to forget.I have cracked open the case and cleaned the lens and spindle without successfully eliminating the U61 error.
I like the Panasonic units because of the tuner, ease of recording steps and it reads my spindle of Memorex +RW discs. I think that newer models require a separate tuner or a convertor box now that the feds mucked it up.
Any assistance is appreciated.
Results 1 to 1 of 1
Panasonic DMR-ES25 "creating" unusable disks
By imageplanet24 in forum DVD & Blu-ray RecordersReplies: 19Last Post: 8th Jul 2010, 08:51 -
musicmatch error message fix
By deanst2 in forum ComputerReplies: 0Last Post: 19th Oct 2009, 17:54 -
DMR-EZ27 records on rewriteable media, but gives U61 error on other media!
By dr-rjp in forum DVD & Blu-ray RecordersReplies: 2Last Post: 11th Jun 2008, 17:58 -
Ripping a +R disk from a Panasonic DMR-es25
By schematic2 in forum DVD RippingReplies: 7Last Post: 23rd May 2008, 01:01 -
Is a U61 Error with Panasonic DVD Recorder Fixable
By wolf01 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 17th Apr 2008, 07:34
