Heard about that too!
And even though my current problem is somewhat solved, I hope to be able to know any other methods to record PAL 60; I sense a need for that soon!
PS: I think I know why I made that error; apparently, the TV card was connected to the TV Out ports of my TV... Will that make any difference?
Results 31 to 54 of 54
Back from some quick testing...
Apparently, most programs do not work with PAL 60 well except Windows Movie Maker so far; it will convert your videos to WMV though...
Clarification: Actually, some programs allow you to watch PAL 60, but as they record only .avi files, they will fail as the output files will be using HCW2 codec, which is somewhat non-existant... =(
The programs are VirtualDub, Windows Media Capture.
DScaler, AmCap and VirtualVCR failed entirely though... =(
Will test with NPVR tonight...Last edited by darkarn; 11th Aug 2010 at 21:24.
I did not even try the newer WinTV7 version.
From what i read about that WinTV7 you can't even use it for normal recording from the external inputs??
Ofcourse S-Video is only available on S-VHS VCR's.
But if you want to make the most out of your PVR-150 you always should try to use it with a S-Video signal.
It is worth to just use a (old, broken) S-VHS/DVDR just for the conversion from composite to S-Video step.
Some old discussion about the Composite/S-Video issue with the PVR15-/500 cards:
SHSPVR: Poor Picture Quality with PVR 150 MCE Analog Capture
SHSPVR: PVR150/500 Comb Tweaks
I will include a file with talked about register tweaks to adjust the comb filters on the PVR150/500, it seems they were lost on the SHSPVR forum.
I don't know if those tweaks still work correctly with the very latest drivers.
I tested also with some cheap (Asus) TV-card based on the Philips SAA713x Chipset.
This card detected PAL-60 automatically and could be captured with Virtualdub, AVI-IO and others.
From what i understand your TV converts the incoming PAL-60 signal back again to the 'normal' NTSC-M standard.
I am quite suprised that it works like that, that is a very nice trick.
What TV did you use for that?
But you should try which gives you the best results.
Connecting you VCR directly and capture in PAL-60 or use your TV to capture in NTSC-M?
Maybe the PVR will work better with the true NTSC-M signal?
Possible the TV will stabilize/improve the signal too?
VHS signals without TBC are notorious unstable, specially the PVR-150 cards are very sensitive for that, causing all sorts of problems.
Yes, the usual problem.
Most of those capture software can't even work correctly in normal PAL/NTSC mode with the PVR-150/500.
The PVR-150 cards use a hardware MPEG2 compression chipset.
Because of this most 'normal' capture software can't work with this correctly.
Even if you manage to get a good picture there is often the problem of no sound.
The older PVR250 series is much more compatible from what i read, you can more easily bypass the HW encoder to use it like a regular 'dumb' capture card.
I still have a PVR250 here to test that out.
So until now the only way i know to to use the PAL-60 and hardware compression with the PVR-150 is with this ChrisPVR trick. -
You can... But no matter what format you choose, you will still be stuck with PAL_B!
Whoa, that will be a tough one...
Thanks, will give them a shot with the new drivers... Which driver have you used these with?
If that's the case, will any card with the Philips SAA713x chipset work?
Unfortunately, I just found out the TV also transmit the same NTSC 3.58 signal the VCR does too!
However, if I can ever produce a PAL 60 signal that becomes a NTSC signal, I will post here...
If only my TV has S-video output...So far, both outputs look the same to me...
Yep, seems to be the case. I am testing out NPVR right now... Will post back soon! -
Yes.
However, if I can ever produce a PAL 60 signal that becomes a NTSC signal, I will post here... -
AH, well maybe there are patches to enable the other video modes.
If not you could try to set your windows country settings to match the video standard you want to use.
I remember now i had to do that too with some TV cards i used in the past.
But i guess you are better off just using the WinTV2000 application, at least that should work.
Maybe, but these days lots of people want to get rid of their video equipment it seems.
I have picked up some JVC S-VHS VCR's (Fully working, even with TBC!) here at a local recycle shop for 10 Euro!.
Seeing all that, once very expensive, equipment there sometimes is all a bit sad to see.
All i know about the drivers is discussed there on the SHSPVR forum, i have no experience with the more recent drivers and composite video input.
Maybe the patches can improve things, but when you use only VHS tape as a source it will be diffcult to see the effect i guess.
It should normally, but ofcourse you never know for sure.
The original ASUS drivers i used for that card worked correctly with PAL-60, but some other generic SAA713x drivers failed on PAL-60.
The resulting capture quality of that card was not that great, at least my old Pinaccle BT878 card with the BTWINCAP driver seemed to do a better job.
I have to say that Asus Tv card was very simple/rudimentary, it did not even have normal A/V connection so had to wire my cables directly to some available jumpers on the board to do some quick tests.
Ah, it already sounded too good to be true ofcourse.
But that is the normal behaviour of most of the (European) TV's they just passing the incoming (SCART) videosignal through to to SCART output, the signal itself is not changed at all.
Doing a real video-standard conversion and/or stabilization is not a simple task.
And the TV-output feature is generally only working with composite video too.
So no S-Video possibilties there.
But funny after all you did not need the whole PAL-60 stuff to do your captures.
But at least the result is a intresting and very informative thread here.
There is a possibility this program can also do it because PAL60 is mentioned in the description: WinTVCap 3.0
But it is a command line driven capture tool, so not so user friendly. -
Sticking with WinTV2000 for now, I can use it to record videos at extremely high bitrates!
Situation's kinda different here... People here have done the same... years ago. Now, it's nearly impossible to get VCRs here, let alone S-VHS VCRs. There is a shop that quoted me 100 SGD for a new VCR though, can't really afford that...
Well, let me try them over the weekend then...
That's amazing!
1. Seems to be the case; my TV is like a passthrough device at best... The video captured looks darker than what is shown on the TV itself for example.
2. Yep, looks like it. But a little more knowledge goes a long way...I must have read too much into those reports on PAL 60...
We can use WinTVCap GUI with that, will make things easier. But I don't see anything in the config files that is about video format so far... -
I wanted to capture a two-hour video before posting my results. Audio drifted on the first long test.
Satstorm warned of this in a post about 6-7 years ago.
Will try again when I get some time.Want my help? Ask here! (not via PM!)
Thanks! And audio drifting is when the audio is no longer in sync with the video, right?
Yes, it's a gradual loss of sync.
I tried to offset the audio by 100.1%, but the source file kept crashing, like it was bad. I dumped the entire capture, and will redo it when I can. My ATI AIW card on my main capture system has PAL60, but it doesn't work correctly with the current drivers. PAL60 is not a friendly format.Want my help? Ask here! (not via PM!)
I have some intresting update on this.
Today I visited my local recycling shop again and what did i see there.... some unknown brand DVDR+HDD for 20 Euro.
So after taking it home i discovered it was a "Oasis Media DVR9407" recorder with a 160GB HDD, in full working order it seems.
After some investigation and (urgently needed) upgrade of the firmware it appears to be a modified version (for the dutch/german market) of the Yakumo DVD Record Master HDD.
I noticed this unit had a universal power supply so that made me think it could possible handle PAL-60.
And YES, it works!
Even more suprising is the fact it can record a PAL-60 signal and also convert the looped through or playback signal to true NTSC-M which i could record again with WinTV2000 and my PVR-150.
Also it can somehow convert between PAL and NTSC if you choose the desired output mode.
A very intresting find i must say, always nice to see how flexible those cheap brands kan operate.
Also it seems you can connect the internal HD to a PC and easily copy the recordings directly without much diffculty.
The only real thing 'missing' on this new 'toy' is the SCART RGB input option.
I did not have time to compare the recording quality with my other capture equipment here but i could easily see the result was already much better then the PAL/PAL-60 VHS captures i did with the TV-cards.Last edited by The_Doman; 13th Aug 2010 at 17:12.
Pal60? That bring back memories! And that reminds me that I still have to convert the Betty Boo VHS collection to DVD one day...
Actually I use an ACE video enhancer unit now, that converts PAL60 back to NTSC. And I capture to NTSC. That make it far easier ...
But that is expensive.
And the only other way to do this correct, is by using any BT8XXX based card, the winbitcap drivers & VirtualVCR. You have to capture on mjpeg to do the trick (I use Pic Video codec myself). I never had any luck with huffyuv or any other video codec. Who knows why... (and my testing about PAL60 ended years ago)
On VirtualVCR just don't forget to lock video / audio, capture as PAL60 and then encode your avi file as NTSC mpeg 2.
S-Video / Composite doesn't really matter. Actually, I think that Composite look better in this case.
PAL60 is a nightmare, but it is nothing compared those 1980s MESECAM tapes...Last edited by SatStorm; 14th Aug 2010 at 08:30.
La Linea by Osvaldo Cavandoli
Be careful there, not any BTXXXcard will work, you need a BT878 or higher chipset to use the PAL-60 (and NTSC50) modes.
And yes the MJPEG/PICVideo codec was, and still is, great.
An for me the best AVI capture tool to keep the A/V perfectly in sync is still AVI-IO.
With VirtualVCR i never got it perfect. -
Ok, I am not sure if this is a related issue, but I just noticed that my recordings have some blurred lines under them... How should I get rid of them?
Are you talking about head switching noise at the bottom of the frame? A dozen scan lines or so? That's head switching noise and it's on the tape. All you can do is mask it or crop it.
Aww man... Will do, thanks; now still recording more tapes, have not encountered a PAL 60 yet...
Of course the PAL-60 format does not exist as a tape format, it's only with playback on european machines you will see that format.
Also i think the Hauppauge PVR-Cards will work better with a true NTSC signal as you now use instead of PAL-60.
There were/are always many issues with the PAL versions of the Hauppauge cards.
Hauppauge PVR-150 Hue and Saturation adjustment
By Spektre in forum Capturing and VCRReplies: 3Last Post: 15th Jun 2011, 10:09 -
capture VHS with Hauppauge PVR 150?
By shun in forum Capturing and VCRReplies: 13Last Post: 24th Jul 2010, 18:11 -
Need help connecting Hauppauge 150 PVR from TV/VCR set up
By magicfingers in forum Capturing and VCRReplies: 17Last Post: 5th Sep 2008, 06:41 -
Hauppauge PVR 150 compatibility with my OS
By GangstaRap in forum Capturing and VCRReplies: 11Last Post: 14th Mar 2008, 10:03 -
hauppauge pvr 150: Need REAL software to record
By SignedupGuest in forum Capturing and VCRReplies: 16Last Post: 19th Feb 2008, 12:40
